Custom DCL Design using ListView DataGridView etc. using AutoLISP
mark.electricaldesign
The Toolbox for DCL creation uses basic controls eg edit_box etc. AutoCad Electrical utilises more advanced controls such as List Views, Tabs Sheets etc. Is there a way to harness these controls in our own LISP routines without the use of external libraries? Below is an example of a Dialog I would like to produce using DCL with AutoLisp
Thanks in Advance
Mark
DataGridView and Tab Sheet Extracted from AutoCad ElectricalDataGridView and Tab Sheet Extracted from AutoCad Electrical
Sea-Haven
It can be done but a lot of work. This a click button for more options.
CodeDing
@mark.electricaldesign ,
THIS source says No, but you can try OpenDCL.
THIS source appears that @Sea-Haven  has already been here and answered the same question similarly.
THIS source gives a mention by Lee Mac that it could be done with an 'image_button' tile but would take a large amount of work (which most likely won't be worth the hassle) (which is what I assume sea.haven means when he says it would be a lot of work).
So it's definitely beginning to appear that another approach would be worth a shot here. Sea.Haven brings a valid solution to the table IMO..
Best,
~DD
