Custom CUI file not loaded on launch using AutoCAD 2024
markhop1
Message 1 of 9
markhop1
Hi everyone,
I have a simple LISP script that loads a custom CUI Panel in my ribbon when AutoCAD launches. For context, it also loads a custom plugin, but that is not relevant to my problem. This is the code I use:
CustomRibbonLoader.lisp
(vl-load-com)
(vla-load (vla-get-menugroups (vlax-get-acad-object)) "./CustomRibbon.cuix")
PackageContents.xml
<ApplicationPackage SchemaVersion="1.0" Version="1.0" ProductCode="XXX" ProductType="Application" Name="Custom Plugin" Icon="./Contents/Resources/logo.ico" HelpFile="./Contents/Resources/en-US/plugin.htm">
    <CompanyDetails Name="CompanyName" Url="www.url.com" Email="info@info.com" Phone=" " />
    <Components>
        <RuntimeRequirements OS="Win64" Platform="AutoCAD*" />
		<ComponentEntry AppName="Custom Plugin" ModuleName="./Contents/Plugin.dll" AppDescription="Custom App" LoadOnCommandInvocation="True" LoadOnAutoCADStartup="False">
			<Commands GroupName="CustomCommands">
				<Command Global="COMMAND1" Local="COMMAND1" />
				<Command Global="COMMAND2" Local="COMMAND2" />
				<Command Global="COMMAND3" Local="COMMAND3" />
			</Commands>
		</ComponentEntry>
        <ComponentEntry AppName="Custom CUIX" Version="1.0.0" ModuleName="./Ribbon/CustomRibbon.cuix" />
        <ComponentEntry AppName="Custom CUIX Loader" Version="1.0.0" ModuleName="./Ribbon/CustomRibbonLoader.lsp" PerDocument="True"/>
    </Components>
</ApplicationPackage>
This code loads the CUIX in AutoCAD 2020, 2021 ,2022, 2023... but unfortunately, not in 2024. I've tried loading my CUIX file manually with CUILOAD and doing so the panel appeared in the ribbon as always.
I need to load the Pallete Panel automatically when the plugin is loaded, as I will not be able to alter manually the AutoCAD of the plugin users.
Is there any modification I can do to my LISP script in order to make it work with AutoCAD 2024?
Thanks in advance.
Replies (8)
Message 2 of 9
paullimapa
Have you tried adding this lisp to startup suite content
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-B38F610B-51FB-4938-BDEC-A0A737F5DB6C
Paul Li
IT Specialist
@The Office
Message 3 of 9
markhop1
@paullimapa  ha escrito:
Hey @paullimapa , thanks for the suggestion.  I just tried to do so, but it is not working neither...
Also, this solution would not help me, as I need to load the Pallete Panel automatically when the plugin is loaded, as I will not be able to alter manually the AutoCAD of the plugin users... I will include this info in the main post.
Message 4 of 9
paullimapa
In addition to adding the folder to Support File Search Paths did you also add the relevant folders to the trusted folders path?
Paul Li
IT Specialist
@The Office
Message 5 of 9
markhop1
Yeah, I placed the CUIX and the LISP files within the default trusted folder:
C:\Users\user\AppData\Roaming\Autodesk\ApplicationPlugins\CustomPlugin\Ribbon
Message 6 of 9
paullimapa
Have you tried instead of
including the complete path to the location of the cuix?
Paul Li
IT Specialist
@The Office
Message 7 of 9
paullimapa
FYI for your packages.xml to load follow this structure
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-40F5E92C-37D8-4D54-9497-CD9F0659F9BB
Paul Li
IT Specialist
@The Office
Message 8 of 9
Sea-Haven
Maybe this example for a method.
(setq Menu_Path "C:\\CAD-TOOLS\\") ; Path to Menu file
(setq Menu_Name "CAD-TOOLS") ; pop menu to load
(setq Group_Name "CADMENU") ; groupname assigned in .mnu or .mns file
(if (menugroup menu_Name)
(command "_MENUUNLOAD" menu_Name)
(setq cnt (vla-get-count(vla-get-menuGroups (vlax-get-acad-object))))
(if  (> (vl-string-search  "BRICSCAD" (strcase(getvar 'product))) 0)
(progn
(command "MENULOAD" (strcat Menu_Path Menu_Name ".cui"))
(menucmd (strcat "P" (rtos (+ cnt 1) 2 0) "=+" menu_Name ".POP1"))
(progn
(command "MENULOAD" (strcat Menu_Path Menu_Name ".cuix"))
(alert "\n Menu loaded \n \n CAD TOOLS programs now installed")
Message 9 of 9
markhop1
Thanks, changing the script worked!
