Custom Autocad Dimension with tolerance (HELP)
Before I attempt writing an autolisp for this.  Figured I would ask to see if anyone already has a program or can help me.
What I am looking to do it use autocad's dimensions but add a small change to it. hopefully it's small.
I'm looking for an autolip program that will first ask me what my tolerance is. (ie  +/- .005) and then once I answer that question.  The lisp program with automatical do the addition and subtract based on the line I clicked to dimension.  I included an image of what I would like it to look like in the end.  This dimension is .500 +/-.005.
sample:
step 1 - click on the lisp program
step 2 - click line you want to dimension or both end points (just like autocad dims)
step 3 - this is what I want it to say in autocad - "Enter Tolerance (.002)" .005 "enter"
step 4 - done  (see image)
I'm hoping using autocad dimensions i can then use autocad's dim style and modify dimensions much easier once a drawing is done.  Right now we are using a custom lisp program that we have to manually type the sizes.  It's an old program from R14.
I'm using autocad 2014 & 2015.
thank you for any help.
3wood
I reckon in your case, no need any routines.
Just set "Tolerances" tab and "Text" tab in your dimension style properly as shown below:
The only thing I haven't worked out is how to make the dimension line pass through both texts without break.
You can also select multiple existing dimension objects and override current texts and style with additional tolerances information from Properties Pallette, as shown below:
Here is the result of my test.
