Current number of layout as a field, not using CTAB
Message 1 of 1
Hello to all, 1st post here.
 I don't know anything about this Lisp universe and knowledge, I managed to put a list code using APPLOAD to add a field for the total number of sheets in my drawing, I used the tutorial located in cadforum.cz about the subject
 A very helpful explanation!
Everything worked fine and now I need something similar for the current number of the layout, not the total, I don't want to use CTAB field because I use code in every name of my sheets so I need the number of the sheet, by example
 / 16 ------>  / 16
/ 16 --------> / 16
the Lisp code I used for the total number is this one:
;Sets totalLayouts automatically - then use Field: %<\AcVar.17.0 Lisp.totallayouts>%
;CAD Studio, 2016
(defun _totalLayoutsReactor (a r)
 (setq totalLayouts (length (layoutlist)))
(vlr-command-reactor nil '((:vlr-commandWillStart . _totalLayoutsReactor)))
Any help would be appreciated, thank you!
Replies (0)
