@Anonymous wrote:
Thank you Sir,
Is there any possibility to update the code to give user input at command prompt for file path and file extensions?.
Advanced thanking you Sir.
Try this.....
(defun C:GFL (/);Put temp Variables
(vl-load-com)
(setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application" ))
(setq folder (vlax-invoke-method sh 'BrowseForFolder 0 "" 0 ))
(vlax-release-object sh)
(setq folderobject (vlax-get-property folder 'Self))
(setq result (vlax-get-property FolderObject 'Path))
(vlax-release-object folder)
(vlax-release-object FolderObject)
(setq extn (getstring "\nEnter The Exten: "))
(setq Fname (getstring T "\nEnter Output Text File Name: "))
(setq Path_T (strcat result "\\" Fname))
(setq F_list (vl-directory-files result (strcat "*." extn)))
(setq File_Text (open Path_T "w"))
(repeat (setq N (length (setq F_list (reverse F_list))))
(setq Data (nth (setq N (- N 1)) F_list))
(write-line Data File_Text)
(close File_Text)
Input should be like.......
Text file would generate at selected folder......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
