Creating incremental variables in AutoLISP
adaptacad
adaptacad
In the example below I ask the user to enter a value and is given continuity to the code...
(defun c:Test ()
  (setq lista '(1))
  (setq n_forcas (cond ((getint "\nnumber of variables <1>: "))
		       (1)))
  (if (> n_forcas 0)
    (progn
      (cond
	((= n_forcas 1)
	 (progn
	   (setq f1 (getint "\variables 1: "))
	((= n_forcas 2)
	  (progn
	   (setq f2 (getint "\variables 2: "))
      )    (Alert "Invalid Input!")
  (princ)
but I would like to create a variable that I could incremental, for example:
 (setq n_forcas (cond ((getint "\ nnumber of variables <1>:"))
(1)))
if I type 1 it will create
(setq f1 (getint "\ variables 1:"))
if I type 2 it will create
(setq f2 (getint "\ variables2:"))
if I type 3 it will create
(setq f3 (getint "\ variables3:"))
4, 5, 6 [...]
Is it possible or not?
cadffm
It is possible.
[F1] Read about lisp function SET (not SETQuote)
and READ
Without testing:
(setq n 0)
(repeat numberofvariables
(set (read(strcat "f" (itoa (setq n (+1))))) (getint (strcat "\nVariable"(itoa n)": "))
Sebastian
scot-65
Look into LIST instead?
Only one variable is needed.
A list can be a collection of various items including other lists. (!)
Use CONS or APPEND to build the list.
Use LENGTH to determine how many items are in the list.
Use CAR CADR CADDR and/or NTH to access the items in the list.
Example tested using 3:
(setq a nil n 0 n1 (getint "How many items: "))
(while (< n n1)
(setq a (append a (list (strcat "variable" (itoa (setq n (1+ n)))))))
);while
(princ a)
Command: (while (< n n1) (setq a (append a (list (strcat "variable" (itoa (setq n (1+ n))))))))
("variable1" "variable2" "variable3")
LISP = LISt Programming
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
adaptacad
@scot-65 @cadffm
I don't understand how this would apply to code
john.uhden
@cadffm is leading you down the correct path.
Since I haven't had a cocktail (yet), I'l just blurt out what comes to mind.
(defun c:Variables ( / N i ans)
  (initget 7)
  (setqq N (getint "\nEnter number of variables do you want to create: "))
  (setq i 1)
  (repeat N
    (and
      (setq ans (getstring T (strcat "\nEnter value for VAR" (itoa i) ": ")))
      (/= ans "")
      (set (read (strcat "VAR" (itoa i))) ans)
    (setq i (1+ i))
  (princ)
;; Untested
Now we can also add conditional formatting to convert the string to a REAL or INT, even feet and inches, and maybe even a LIST.
We can also make it where you don't have to choose how many variables to set, as an empty response could stop the cycle.
Bear in mind that these variables will most likely remain global, but there's a way to handle that too.
John F. Uhden
john.uhden
Hey, dimwit, where is the setqq function defined?  :]
John F. Uhden
