01:02 AM
Hi everyone,
I wonder if you could help me, I have this code(below),
that when the user pick 2 lines it creates another line between them, but it doesn't work when you pick construction lines,
can you fix this to work with construction line too?
Thank you.
Eyal
;; LineBetween.lsp [command name: LB] ;; To draw a Line whose endpoints are halfway Between those of two ;; User-selected Lines or Polyline [of any variety] line segments. ;; Draws Line on current Layer. ;; Accounts for Lines or Polyline line segments running generally in ;; same or opposite directions, and for 3rd dimension if applicable. ;; May draw Line between "wrong" halfway-between points if objects ;; cross, or if one crosses their apparent intersection, because routine ;; has no way to judge which possibility is expected -- try reversing ;; one object to get "right" result. ;; Result will not necessarily lie along angle bisector between selected ;; objects; will do so only if objects' relationship is symmetrical. ;; Kent Cooper, 5 March 2013 (defun C:LB ; = Line Between (/ *error* noZ svnames svvals esel ent edata etype pick s1 e1 s2 e2 int) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ); if (command "_.undo" "_end") (mapcar 'setvar svnames svvals) (princ) ); defun - *error* (defun noZ (pt) (list (car pt) (cadr pt))) (setq svnames '(cmdecho aperture); = System Variable NAMES svvals (mapcar 'getvar svnames); = System Variable VALueS ); setq (mapcar 'setvar svnames (list 0 (getvar 'pickbox))) ; aperture = pickbox to prevent Osnap Center seeing wrong object (command "_.undo" "_begin") (foreach num '("1" "2") (while (not (and (setq esel (entsel (strcat "\nSelect Line/Polyline line segment #" num ": "))) (setq ent (car esel) edata (entget ent) etype (cdr (assoc 0 edata)) pick (osnap (cadr esel) "nea"); for (vlax-curve-...) later ); setq (wcmatch etype "LINE,*POLYLINE") (not (osnap pick "_cen")); if Polyline, not fit-curved or on arc segment (if (= etype "POLYLINE") (= (boole 1 4 (cdr (assoc 70 edata))) 0) T) ; not spline-curved 2D "heavy" or 3D Polyline [T for Line] ); and ); not (prompt "\nNothing, or Polyline curve, or invalid object type, selected --") ); while (set (read (strcat "s" num)); s1 or s2 [start] (if (= etype "LINE") (cdr (assoc 10 edata)); then (vlax-curve-getPointAtParam ent (fix (vlax-curve-getParamAtPoint ent pick))); else ); if ); set (set (read (strcat "e" num)); e1 or e2 [end] (if (= etype "LINE") (cdr (assoc 11 edata)); then (vlax-curve-getPointAtParam ent (1+ (fix (vlax-curve-getParamAtPoint ent pick)))); else ); if ); set ); foreach (setq int (inters (noZ s1) (noZ s2) (noZ e1) (noZ e2))); T or nil -- opposite directions (entmake (list '(0 . "LINE") (cons 10 (mapcar '/ (mapcar '+ s1 (if int e2 s2)) '(2 2 2))) (cons 11 (mapcar '/ (mapcar '+ e1 (if int s2 e2)) '(2 2 2))) ); list ); entmake (command "_.undo" "_end") (mapcar 'setvar svnames svvals) (princ) ); defun (prompt "\nType LB to draw a Line halfway Between two Lines/Polyline line segments.")
