creating construcion line between 2 construction lines or lines or polylines
Hi everyone,
I wonder if you could help me, I have this code(below),
that when the user pick 2 lines it creates another line between them, but it doesn't work when you pick construction lines,
can you fix this to work with construction line too?
Thank you.
Eyal
;;  LineBetween.lsp [command name: LB]
;;  To draw a Line whose endpoints are halfway Between those of two
;;    User-selected Lines or Polyline [of any variety] line segments.
;;  Draws Line on current Layer.
;;  Accounts for Lines or Polyline line segments running generally in
;;    same or opposite directions, and for 3rd dimension if applicable.
;;  May draw Line between "wrong" halfway-between points if objects
;;    cross, or if one crosses their apparent intersection, because routine
;;    has no way to judge which possibility is expected -- try reversing
;;    one object to get "right" result.
;;  Result will not necessarily lie along angle bisector between selected
;;    objects; will do so only if objects' relationship is symmetrical.
;;  Kent Cooper, 5 March 2013
(defun C:LB ; = Line Between
  (/ *error* noZ svnames svvals esel ent edata etype pick s1 e1 s2 e2 int)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    ); if
    (command "_.undo" "_end")
    (mapcar 'setvar svnames svvals)
    (princ)
  ); defun - *error*
  (defun noZ (pt) (list (car pt) (cadr pt)))
  (setq
    svnames '(cmdecho aperture); = System Variable NAMES
    svvals (mapcar 'getvar svnames); = System Variable VALueS
  ); setq
  (mapcar 'setvar svnames (list 0 (getvar 'pickbox)))
    ; aperture = pickbox to prevent Osnap Center seeing wrong object
  (command "_.undo" "_begin")
  (foreach num '("1" "2")
    (while
      (not
        (and
          (setq esel (entsel (strcat "\nSelect Line/Polyline line segment #" num ": ")))
          (setq
            ent (car esel)
            edata (entget ent)
            etype (cdr (assoc 0 edata))
            pick (osnap (cadr esel) "nea"); for (vlax-curve-...) later
          ); setq
          (wcmatch etype "LINE,*POLYLINE")
          (not (osnap pick "_cen")); if Polyline, not fit-curved or on arc segment
          (if (= etype "POLYLINE") (= (boole 1 4 (cdr (assoc 70 edata))) 0) T)
            ; not spline-curved 2D "heavy" or 3D Polyline [T for Line]
        ); and
      ); not
      (prompt "\nNothing, or Polyline curve, or invalid object type, selected --")
    ); while
    (set (read (strcat "s" num)); s1 or s2 [start]
      (if (= etype "LINE")
        (cdr (assoc 10 edata)); then
        (vlax-curve-getPointAtParam ent (fix (vlax-curve-getParamAtPoint ent pick))); else
      ); if
    ); set
    (set (read (strcat "e" num)); e1 or e2 [end]
        (cdr (assoc 11 edata)); then
        (vlax-curve-getPointAtParam ent (1+ (fix (vlax-curve-getParamAtPoint ent pick)))); else
      ); if
    ); set
  ); foreach
  (setq int (inters (noZ s1) (noZ s2) (noZ e1) (noZ e2))); T or nil -- opposite directions
  (entmake
    (list
      '(0 . "LINE")
      (cons 10 (mapcar '/ (mapcar '+ s1 (if int e2 s2)) '(2 2 2)))
      (cons 11 (mapcar '/ (mapcar '+ e1 (if int s2 e2)) '(2 2 2)))
    ); list
  ); entmake
  (princ)
); defun
(prompt "\nType LB to draw a Line halfway Between two Lines/Polyline line segments.")
Kent1Cooper
Thank you !!!
It's better than I wanted.
Eyal
