Creating/Appending a Dimension through LISP
I've got the following bit of code and I can't seem to figure out why it won't create the dimension object.
(defun C:DIMDIA (/ pr cl osm obj rad ep sp ss count newdim d )
	(setvar "cmdecho" 0)										;Variables
	(setq pr (getvar "luprec"))
	(setq cl (getvar "clayer"))
	(setq osm (getvar "osmode"))
	(setvar "osmode" 0)
	(if (= (getvar "lunits") 2) (setvar "luprec" 3))
	(setq obj (vlax-ename->vla-object (setq e (car (entsel "\nSelect circle to Dimension: ")))))
	(if (= (vla-get-objectname obj) "AcDbCircle")
		(progn
			(setq rad (vla-get-radius obj))
(setq f (getpoint "\nLeader Location: ")) (command "LAYER" "M" "DIM" "") (command "AMPOWERDIM_DIA" e f ) (princ "\nSelect Circles for hole count") (setq ss (ssget (list '(0 . "CIRCLE")(cons 40 rad)))) (if (/= (setq count (sslength ss)) 0) (progn (setq newdim (entlast)) (setq d (strcat "<>" "[]" " (" (itoa count) " PLACES)")) (command "dimedit" "n" d newdim "") ) ) ) (princ "\nSelected Object is not a circle.") ) (setvar "clayer" cl) (setvar "luprec" pr) (setvar "osmode" osm) (princ) )
It seems to completely skip over the (command "AMPOWERDIM_DIA" e f ) portion of code, while the rest of it executes flawlessly, instead altering the previously placed dimension.
Also, would there be a way to show the preview of the dimension location before its placed? I tried nesting the (getpoint) within the "AMPOWERDIM_DIA" command, but no such luck, though that might be tied to the first issue.
ronjonp
I don't have AutoCAD Mechanical but if you want to see the placement of the dimension try this:
(command "AMPOWERDIM_DIA" e "\\" )
And comment out:
dbhunia
Try with this change....
	(setvar "osmode" 0)
	(setq obj (vlax-ename->vla-object (car (setq e (entsel "\nSelect circle to Dimension: ")))))
		(progn
			;(command "AMPOWERDIM_DIA" e f )
			(command "AMPOWERDIM_DIA" (cadr e))
			;(command "DIMDIAMETER" (cadr e));;; Or Try this
			(while (/= (getvar "cmdactive") 0)(command f))
				(progn
	(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Well, that seems to fix the first issue.
Oddly enough, now I'm getting an error about invalid selection expecting single object after selecting holes, though nothing has changed for that piece of code.
Scratch that, it only doesn't work with AMPOWERDIM_DIA. Using DIMDIAMETER works fine.
Thanks for the help, both of you.
dbhunia
You Welcome 🙂
Debashis Bhunia
