Create new file, with more text
lmnDCJSJ
lmnDCJSJ
I want to make a lisp that crates a new file, based on the current file i am working with.
I want to add "_FINAL" to the filename.
i have this at the moment, but i dont get the "_FINAL" added
(defun c:Finalcreate()
setq fPath (getvar 'dwgprefix)
setq fName (getvar 'dwgname)
(command "saveas" "2010" (strcat fPath fName "_FINAL"))
(command "qsave")
(princ)
Best would be if it automatic owerwrate the file, if it exists.
AND if the file, currently in use has "__" 2 x underscore , all after the "__" should be erased before adding _FINAL to the filename.
I am currently doing this manually, and it is taking SO much time 😞
Moshe-A
@lmnDCJSJ
for the first part of your question:
the result of saving with SAVEAS command would make that file current and than you QSAVE the file again which is redundant. so i suggest to change it to use SAVE command (instead of SAVEAS) but this won't let you to specify the dwg format so do it in OPTIONS.
the expert=5 sysvar is to tell autocad to skip alerting of existing file.
if the file in question is already open? that's another 'story' to VisualLISP\ActiveX to be solve.
moshe
 (setq fPath (getvar 'dwgprefix))
 (setq fName (getvar 'dwgname))
 (setvar 'expert 5)
 (command "save" (strcat fPath fName "_FINAL"))
 (command "qsave")
 (setvar 'expert 0)
 (princ)
dbhunia
this code will replace also
(setq fsl (strlen fName))
(setq fsl (- fsl 4))
(setq file (strcat fPath fName "_FINAL.dwg"))
(if (findfile file)
(vl-file-delete file)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
lmnDCJSJ
@Moshe-A
Thanks it works, but the filename has the .dwg embedded in the new filename.
eg: file1.dwg becomes file1.dwg_FINAL.dwg
Can i somehow use substr to remove the LAST 4 (.dwg)?
dbhunia
(command "qsave")
(princ)
Try this ...
(while
(wcmatch fName "*_*")
(setq fName (vl-string-subst "" "_" fName))
(setq Fname (substr fName 1 fsl))
(if (findfile file)
(princ)
Debashis Bhunia
lmnDCJSJ
@dbhunia
Works like i wanted 🙂 thanks.
