Create Line Type entering the two lines instead of a .lin name
GeryKnee
Message 1 of 21
GeryKnee
Hello to everyone.
User defined Line Types are based on a two lines string
Example
*MAP,--- Map ---
A,1.0,-0.5,["Map",mcstyle,S=1,R=0,X=0,Y=-0.5],-3.0
The text, i see, is inserting to autocad system by using a .lin txt file.
This causes time delay because of restoring from disk this simple string.
Is there a way to insert the string to autocad app not using the fi
Replies (20)
Message 21 of 21
Sea-Haven
I still think like Kent using mtext is still a better way to go you can move text, delete or add more.
How are you getting the original data is it csv and does it have a Z. Could import and label all in one go.
