Create Line and Arc using COGO method
MehtaRajesh
MehtaRajesh
Hi
Please help me by providing a code to create Line and Arc using COGO method to be used in AutoCAD
I had written the function but it is not giving the required result in all conditions.
Thanks in advance for your quick support
Rajesh
Ranjit_Singh
Elaborate a little more. COGO stands for Coordinate Geometry points. It's not a method. Points can be used in many ways to draw entities. How do you want to draw line and arc, any relationship between the two? What function do you have so far? Post it so we can understand the goals.
MehtaRajesh
Hi Ranjit,
I need to draw Line, dimensions (BEARING: N20 degree 46'13"E,   LENGTH 18.85')
Arc dimensions (DELTA: 16 degree 43'26", RADIUS: 486.83', ARC: 142.10', CHORD BEARING: S48 degree 51'28" E, CHORD: 141.50')
Rajesh
john.uhden
Are you aware that Civil 3D has commands to do what you want?
John F. Uhden
MehtaRajesh
Hi John,
I am aware of all COGO feature of Civil 3D,
But I need to develop program for plain AutoCAD.
Rajesh
john.uhden
How about if you post what you have so far?
John F. Uhden
Kent1Cooper
My PROPERTY.lsp routine, available here, may do what you want, or at least much of it.  Try the commands with D in the middle [to Draw, rather than to Label already-drawn, Lines or Arcs].
Kent Cooper, AIA
