Create Group of block and mtext
jan_tappenbeck
Message 1 of 8
jan_tappenbeck
hi!
i want to create a simple group of a mtext and a block insert.
the objectID's are my information ...
did someone had an idea?
regards Jan
Replies (7)
Message 2 of 8
komondormrex
hi,
a group out of existing insert and mtext?
Message 3 of 8
Kent1Cooper
Are the "objectID's" that you have their entity names, such as would be returned by (entlast) or (car (entsel "\nSelect a Block insertion or Mtext object: "))?  And how do you have them as information?  Are they stored in AutoLisp variables?  Are they already in an AutoLisp selection set together?  An AutoLisp list?  An external file of some kind?  Etc., etc.
Do you want the Group to be named ?
Kent Cooper, AIA
Message 4 of 8
jan_tappenbeck
yes of existing entities.
Jan
Message 5 of 8
jan_tappenbeck
the objectid's are long values.
example:
Dim MTextId As New ObjectId
MTextId = acBlkTblRec.AppendEntity(acMText)
jan
Message 6 of 8
Kent1Cooper
example:
I'm not familiar with that kind of identifier.  Where does it come from?  How do you get it from the object?
Also, it all looks very generic.  Is it any different for one Mtext [or other] object than it is for a different one?  I would expect something probably numerical or hexadecimal as part of it, that would differ between the ObjectId's of different objects.
Kent Cooper, AIA
Message 7 of 8
CADaSchtroumpf
This ?
(defun c:jan_group ( / ss_blk ss_mtxt lst_grp newdict xname)
  (princ "\nSelect a block insert")
  (while (null (setq ss_blk (ssget "_+.:E:S" '((0 . "INSERT")))))
    (princ "\nIsn't a block insert")
  (princ "\nSelect a MText")
  (while (null (setq ss_mtxt (ssget "_+.:E:S" '((0 . "MTEXT")))))
    (princ "\nIsn't a MText")
  (setq
    lst_grp (cons (cons 340 (ssname ss_blk 0)) lst_grp)
    lst_grp (cons (cons 340 (ssname ss_mtxt 0)) lst_grp)
  (setq
    newdict (cdar (dictsearch (namedobjdict) "ACAD_GROUP"))
    xname
    (entmakex
      (append
          (0 . "GROUP")
          (100 . "AcDbGroup")
          (300 . "Block and MText")
          (70 . 0)
          (71 . 1)
        lst_grp
  (if (not (assoc 3 (dictsearch (namedobjdict) "ACAD_GROUP")))
    (dictadd newdict "BLOCK-MTEXT_1" xname)
    (dictadd newdict (strcat "BLOCK-MTEXT_" (itoa (1+ (atoi (substr (cdr (assoc 3 (dictsearch (namedobjdict) "ACAD_GROUP"))) 11))))) xname)
  (prin1)
Message 8 of 8
jan_tappenbeck
thanks for answer.
i forgot to write i use a way in vb.net.
regards Jan
