Visual LISP, AutoLISP and General Customization
Create a popup (dialog box) with selections to run scripts, lisps
6 REPLIES 6
804 Views, 6 Replies
I'd like to create a button that pops up a dialog box in AutoCAD (2009 or 2010) with 5 or 6 radio buttons for selection. Then depending on the selection, run the script or lisp under the button selected. What's the general process to achieve this?
6 REPLIES 6
Why not connect the scripts and 'lisps' to a vanilla flyout on a vanilla
toolbar ? This sounds somehow like using a plier to manipulate a plier !
Humans are born with a wide horizon.
As time goes by, the horizon narrows and
narrows, until it becomes a point of view.
a écrit dans le message de news:
6264484@discussion.autodesk.com...
M_Hensley
You need to write a DCL file defining your dialog box. You can then control it from a lisp program.
It may help to start off with an example that is similar to what you want and try to modify it, or maybe download OpenDCL and see if that is easier for you.
I was just curious how I would go about making a popup in AutoCAD. True, a ribbon or toolbar button with a flyout would be acceptable. Now you did it, LOL. I'd like to know how to create a ribbon section for this as well. Any suggestions? What is presently recommended by Autodesk regarding developing current customization for AutoCAD users? Keeping in mind any methods that may no longer be supported in the near future...
kinda opening a can of worms on this huh? 😉
Thank you. Edited by: powermixx on Oct 1, 2009 7:55 PM
Thanks for the info. Looking over it quickly, it looks a lot like Visual Basic. In general, how would I package, compile, deploy, etc. for AutoCAD?
You don't need to go as far as VB in order to have that simple dialog if you
really want to go that way. DCL or ODCL is far more accessible. The problem
with DCL is that DCL GUIs are modal and then not everything can be run
behind a modal dialog in AutoCAD, especially programs that require screen
selection and stuff.
So you will have to select the command and then to dismiss the DCL dialog in
order to continue, which makes three mouse clicks using this approach
comparing with one with a toolbar button and two with a flyout. But if you
really want it, try the attached one.
Assuming that you have a LISP file named COMMANDS.LSP placed in a declared
path and you have six commands defined in that file named command_a to
command_f, then you could call the attached function from a tool bar button
or menu item like this:
^C^C(call_lisp "commands.lsp")
Look inside the function and remark that the radio button keys are named
with the name of the six commands defined in the LISP file. This is very
important with this setup.
HTH
6264529@discussion.autodesk.com...
AutoCAD Inside the Factory
