counting different geometries as blocks
dani-perez
405Aufrufe
6Antworten
Nachricht 1 von 7
dani-perez
Hello all,
I received a DWG scanned in PDF. It has many layouts and I have to count different elements: bulbs, bathtubs...if I explode the PDF, all elements are broken down into lines, circles, arcs (no blocks), and all of them, in the same layer.
Is there a way (or a LISP) to select a pattern of basic elements (lines, circles...) that form a block, then, select an area of the viewport, and receive the number of exact matches of the pattern (a kind of pattern filter)?
Thanks all.
0 „Gefällt mir“-Angaben
406Aufrufe
6Antworten
Antworten (6)
Nachricht 2 von 7
ronjonp
If you have access to Bricscad they have a command called "Blockify" that you could use.
Nachricht 3 von 7
jtohill
have you tried pdf import.
Nachricht 4 von 7
dani-perez
No, I do not have access to Briscad
Nachricht 5 von 7
dani-perez
Yes, but unsuccessfully
Nachricht 6 von 7
Sea-Haven
I think there is an alternative to the Bricscad solution I can not remember who, I have a suspicion will try to find.
If the BLOCK object has an outer shape like a circle then may be able to do some real rough counting by using approx radius.
Post a dwg with the objects so we can see what your trying to convert/count.
Nachricht 7 von 7
ВeekeeCZ
Try to search the board for "blockify". I know that @marko_ribar has his own routine for this purpose, you should be able to find it.
EDIT:
Just realized that the new COUNT feature actually CAN count geometry from exploded blocks (or just same/similar/rotated/scaled as some existing block). They are identified as "errors". I did just a quick test - did not find a way to "fix the errors" by "blockifing" them.
The screenshot from 2022:
