Hello dear People of the Autodesk-Forum!
First of some Info about me and the system I use:
-I am and technical-product-design-Aprentice in my second (out of 3.5years) year of Vocationaltraining.
-In our Buisness we use AutoCAD 2021
-We are using Windows 10
-I work on an professional CAD-Workstation PC, newly build in 2020
-My first language is German so i hope everything is translated correctly (should there be any confusion, translation wise, please let me know 🙂 not only to state my problem correctly but also to further better my english speaking Capabilities)
I may need your help here!
Problem: I need to find a way to count the number of different Blocks within a given Object.
Background:
Our Buisness produces Paneling/covers to put inside light-Commercial-Vehicle´s Stowages.
To make creating partslists of single-part-Drawings (and Assembly-Drawings) less prone to Errors and also way easier, we want to establish the useage of Blockdefinitions and -refferences. I already converted the (for example) boreholes and other Objects into simple Blocks. Since the amount of Screws (# of screws = # of boreholes) will be refferenced, not only in the Assembly drawing but the single-part-Drawing also, I need to find a way to define a space/Object (outer Contour of the Paneling) and be able to count how many of wich Block are placed in that given Object. Maybe there is something similar to the Textfield command that lets you select an Object and shows you (for example) the Area or length/circumference of the Object you have selected and also Updates the Data when changes are made.
Up until now i did not find a way to specify an Object/Space in wich the blocks are supposed to be counted.
but I am sure it is way easier than I think or i am just too bad at looking for the right command.
I am excited to find out if you guys are able to help me out here 🙂
