Count Number of Block Inside a Polygon then Update the Table Using LISP
Hello, Experts!
Do you have a lisp that can count the number of blocks listed inside a polygon then updates the table with the correct count?
I attached the dwg file for testing.
LISP should work like this:
User: Run the command.
User: Select Polygon.
Program: Count the number of B1 & B2 inside the Polygon but disregard B3.
Program: Pop up message "Table is Updated"
pbejse
@Anonymous wrote:
Hello, Experts!
(defun c:demo (/ col ss blk strs n el bn tgnme pts)
  (Setq	lst
	 '(("B1" "B1C")
	   ("B2" "B2C")
  (if
    (and
      (setq coll nil
	    ss	 (ssget '((0 . "LWPOLYLINE")))
      (setq blk (ssget "_X" '((0 . "INSERT") (2 . "BTable"))))
     (progn
       (repeat (setq i (sslength ss))
	 (setq e   (ssname ss (setq i (1- i)))
	       pts (mapcar 'cdr
			   (vl-remove-if-not
			     '(lambda (x) (= (car x) 10))
			     (entget e)
	 (if
	   (setq strs (ssget "_CP" pts '((0 . "INSERT") (2 . "B1,B2"))))
	    (repeat (setq n (sslength strs))
	      (setq e1 (ssname strs (setq n (1- n)))
		    bn (getpropertyvalue e1 "BlockTableRecord/Name")
	      (if (Setq f (assoc bn coll))
		(setq coll (subst (list bn (1+ (cadr f))) f coll))
		(setq coll (cons (list bn 0) coll))
	(and
	       (foreach	itm coll
		 (setq tgnme (assoc (Car itm) lst))
		 (setpropertyvalue
		   (ssname blk 0)
		   (cadr tgnme)
		   (itoa (Cadr itm))
		 itm
       		(alert "Table is Updated")
  (princ)
HTH
@pbejse
Almost there the only problem is the count is always short by 1 unit
pbejse
@Anonymous wrote:
@pbejse
oops, my bad..
change this..
(list bn 0)
to
(list bn 1)
HTH
@pbejse
Exactly what i need!
Thank you!
pbejse
@Anonymous wrote:
@pbejse
Thank you!
You are welcome, glad it works for you
Cheers
very good and simple tool
