@Anonymous wrote:
Hello, Experts!
Do you have a lisp that can count the number of blocks listed inside a polygon then updates the table with the correct count?
I attached the dwg file for testing.
LISP should work like this:
User: Run the command.
User: Select Polygon.
Program: Count the number of B1 & B2 inside the Polygon but disregard B3.
Program: Pop up message "Table is Updated"
(defun c:demo (/ col ss blk strs n el bn tgnme pts)
(Setq lst
'(("B1" "B1C")
("B2" "B2C")
(if
(and
(setq coll nil
ss (ssget '((0 . "LWPOLYLINE")))
(setq blk (ssget "_X" '((0 . "INSERT") (2 . "BTable"))))
(progn
(repeat (setq i (sslength ss))
(setq e (ssname ss (setq i (1- i)))
pts (mapcar 'cdr
(vl-remove-if-not
'(lambda (x) (= (car x) 10))
(entget e)
(if
(setq strs (ssget "_CP" pts '((0 . "INSERT") (2 . "B1,B2"))))
(repeat (setq n (sslength strs))
(setq e1 (ssname strs (setq n (1- n)))
bn (getpropertyvalue e1 "BlockTableRecord/Name")
(if (Setq f (assoc bn coll))
(setq coll (subst (list bn (1+ (cadr f))) f coll))
(setq coll (cons (list bn 0) coll))
(and
(foreach itm coll
(setq tgnme (assoc (Car itm) lst))
(setpropertyvalue
(ssname blk 0)
(cadr tgnme)
(itoa (Cadr itm))
itm
(alert "Table is Updated")
(princ)
HTH
