Count nested blocks arrayed within a dynamic block.
leothebuilder
Advisor Advisor
leothebuilder
Is there a way to count arrayed blocks within a dynamic block and display this in text or attribute or field?
E.g. I have a system wall that is made up of panels. Each panel is a block.
I have this in a dynamic block that can be stretched (arrayed) to any number of panels.
How can I count the panels within the dynamic block and display the result.
There will be multiple inserts of this dynamic block and each insert would display the number of panels.
Any help would be appreciated.
ojuris
hi!
I think you can use attribute with field
try attachment
leothebuilder
Thank you. This is precisely what I am looking for.
I see you have a formula that displays the number of blocks, but I am not sure how you create this formula.
Can you share how to do this?
ojuris
leothebuilder
Thank you.
I did a bit of reverse engineering on your block and figured out you were using the distance parameter in the formula.
Thank you for posting the video too. Very helpful.
