Correctly setting UCS Location and Angle through Lisp
SORONW
SORONW
Hi All,
I'm trying to use the follow snipet of code, to set my UCS according to 2 points and it seems to have some inconsistencies that I haven't been able to iron out. It will sporadically not follow the Ortho and go in a seemingly random direction.
(defun c:test (/ Origin1 Origin2 )
(progn
		(setq 	Origin1 (getpoint "\n Origin of Part:")) 	;Prompt user for placement and angle of parts
		(setvar "orthomode" 1)
		(setq	Origin2 (getpoint Origin1 "\n Angle of Part:"))
		(command "_.UCS" Origin1 Origin2 "")
 Any guidance you can provide would be much appreciated.
Jonathan3891
Are you aware that this is not necessary what so ever?
When you activate the "UCS" command the default option allows you to do exactly this. I mean if you really want a command to do this, then it would look like this;
(defun c:ttt ()
(command "ucs" pause pause "")
(setvar 'orthomode 1)
Jonathan Norton
Blog | Linkedin
SORONW
I should have been a bit clearer, I'm using this as part of a larger routine to define a temporary ucs to draw several shapes. The rest of the routine works as intended, so I took this little section out to iron out some of the issues.
Jonathan3891
Deleted
Jonathan Norton
Blog | Linkedin
Kent1Cooper
This looks like a case for the classic question:  Do you sometimes have any running Object Snap mode(s)?  Does it ever have the problem when Osnap is off?
Kent Cooper, AIA
