correct use of DXF (-4. )
2 REPLIES 2
Michiel.Valcke
713 Views, 2 Replies
I'm pretty rusty at AutoLisp, but I have been recently getting more active with it again.
For a routine I'm creating. I allow the user to pick polylines and I filter them out based on whether they are closed or not.
So I have the following setq
(setq polygonpolylines
          (ssget
                      '((0 . "LWPOLYLINE")
                         (-4 . (70 . 1)(70 . 129)(-4. "OR>"))
I'm filtering both on the 1 and 129 dxf 70 value, because I want to select all closed polylines independent of their plinegen value.
But somehow I don't get the -4 OR to work correctly, at this point it still only selects polylines with dxf (70 . 1) all closed polylines with plinegen enabled are filtered out, but I want them to be included.
Thanks for your time guys
2 REPLIES 2
cadffm
in reply to: Michiel.Valcke
; your way, just fixed
(sssetfirst nil
          (ssget
                       ;(-4 .       (70 . 1)(70 . 129)(-4. "OR>") ) <- your line
                        (-4 . "<or")(70 . 1)(70 . 129)(-4 . "OR>")
; smarter, but not easier for you to understand / not so easily to read
(sssetfirst nil
          (ssget  '((0 . "LWPOLYLINE")(-4 . "&")(70 . 1)))
Sebastian
Michiel.Valcke
in reply to: cadffm
The second way is a lot cleaner indeed, I was so focused on where I went wrong with the (-4 . "or") that I completely forgot that I could just check to see if any value contained the 1 bit.
Thanks a lot
AutoCAD Inside the Factory
