copy selected objects to selected points
cool.stuff
cool.stuff
Hi!
I need a lisp to copy selcted objects to selected points.
I've found this:
https://www.cadtutor.net/forum/topic/50163-copy-and-paste-on-multiple-points/
The proble is that if I use a diferent ucs it assumes the global not the local, I think..
Can someone help please?
Many thanks!
  • Lisp
ВeekeeCZ
Try this change
(setq pt (cdr (assoc 10 (entget entpt))))
to
(setq pt (trans (cdr (assoc 10 (entget entpt))) 0 1))
cool.stuff
It works like a charm! :))
Many thanks!!!
stevor
If trans worked, and you have more to do,
this old subr is the same:
; return UCS coords
(DeFun Dxf_EU (gn edL / vv )
 (if (and (setq vv (cdr (assoc gn edL)))
               (member gn (list 10 11 210 )))  ; others  codes may exist
   (trans vv (cdr (assoc -1 edl)) 1) vv ) )  ;
S
