Copy block definition from another drawing: Lisp Help
gccdaemon
gccdaemon
Need help with this. Not sure what's going wrong. Looked for several variations and keep getting this error message:
; error: Automation Error. Problem in loading application
(defun GETBLOCK (DWG BLK / DBX)
	(vl-load-com)
	(setq DBX	(vla-GetInterfaceObject (vlax-get-acad-object) "ObjectDBX.AxDbDocument"))
	(vla-open DBX DWG)
	(vla-CopyObjects DBX	(vlax-safearray-fill	(vlax-make-safearray vlax-vbObject '(0 . 0))
							(list (vla-item (vla-get-blocks DBX) BLK)))
				(vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
	(vlax-release-object DBX)
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
hmsilva
HI Andrew,
try
(if (< (atoi (substr (getvar "ACADVER") 1 2)) 16)
        (setq DBX (vlax-create-object "ObjectDBX.AxDbDocument"))
                     (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))
Hope this helps,
Henrique
gccdaemon
Yah, it's working now. A few quick questions since I'm still learning and all. How does the ACADVER variable play into this? Is it related to the object creation in the current drawing? If so why would it matter what version?
Working Code:
	(vl-load-com)
	(if	(<	(atoi	(substr (getvar "ACADVER") 1 2)	)	16)
		(setq DBX (vlax-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))))
	(vla-open DBX DWG)
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
hmsilva
Andrew,
Prior to AC2004, "ObjectDBX.AxDbDocument"
after AC2004, (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))
I also would suggest, to test first 'dwg' with 'findfile', and test the 'blk' existence at block collection with something like this
(if (not
      (vl-catch-all-error-p
        (vl-catch-all-apply
          (function (lambda () (setq blkdbx (vla-item (vla-get-blocks dbx) blk))))
  (vla-copyobjects
    dbx
      (list blkdbx)
Hope this helps,
Henrique
