Copy Attribute to clipboard
jason.lEZRWT
Message 1 of 13
jason.lEZRWT
Hi All. First time poster.
I'm looking for something I feel should be pretty easy, but just not finding it. I need to get an Attribute value from one block and paste it into multiple different blocks (different TAG).
Currently routine is:
- Double Click Source Attribute
- Ctrl C
- Mouse over to Enhanced Att Editor
- Click OK to close
- Select all destination Blocks
- Find appropriate Att in the Propeties
- Ctrl V
At the very least I'd like to be able to:
- Select tool (or type command),
- Click on any visible Attribute and have its value copied to the clipboard
- Ctrl V
I'm mostly just trying to eliminate the whole Enhanced Att Editor part, but if anyone has any better suggestions, I'm all ears. I have to do this a lot and any eliminated clicks, keys, or mice are helpful.
It would be super awesome to eliminate the Ctrl V at the end but I'm sure that would kick up the complexity a bit.
Replies (12)
Message 2 of 13
pbejse
If the target blocks are on the same drawing, there would be no need to Ctrl C and Ctrl V at all. It couldn't be that hard to write a code that is suited to your requirements. But what do you think is missing here? If we could only see a sample drawing....  🤔
A simple code could be like this
(defun c:tf (/ astc)
  	(vl-load-com)
 	(setq astc (vla-get-textstring
    	(vlax-ename->vla-object
      		(car (nentsel "\nSelect Text: "))))
  (while (setq trgt (vlax-ename->vla-object (car (nentsel "\nText to change: "))))
  	(vlax-put-property trgt 'TEXTSTRING astc)
HTH
Message 3 of 13
Kent1Cooper
It doesn't eliminate the Ctrl+V part, but at least you can skip the Attribute-editor middle-man, this way:
(cdr (assoc 1 (entget (car (nentsel "\nSelect Attribute to get value from: ")))))
That will put the contents in the command line, whence you can Ctrl+C copy it for pasting in at the Properties palette.  I'm sure there's a way to feed it to the clipboard for you instead of [or in addition to] the command line [so you don't need to do the Ctrl+C part] -- I'll let you Search for that.
EDIT:  For brevity, at least, >this< looks promising as a way to do that.
Kent Cooper, AIA
Message 4 of 13
jason.lEZRWT
Thank you so much for getting back. Here's the details and a sample drawing.
I'm working on Wiring Schematics. The wires need to be associated with the Source and Destination connectors. The connectors have attribute Ref_Des (shown in green). The wires have attributes SOURCE_REFDES and DEST_REFDES. The connector attribute needs to be copied to the wires SOURCE_REFDES or DEST_REFDES respectively.
As noted below, I'm currently copying the connector REF_DES via Enhanced Att Editor, selecting all applicable wires, and pasting the value via the properties window.
Message 5 of 13
jason.lEZRWT
Current Routine. Didn't note before that there's some ESCs in there too.
Message 6 of 13
ВeekeeCZ
Select the wires first, then pick a source and desc. Or just one of them, and RT click for the other....
(vl-load-com)
(defun c:WC ( / w s d i e)
  (princ "Select wires, ")
  (setq w (ssget '((0 . "INSERT"))))
  (and (setq s (car (nentsel "\nSource: ")))
       (setq s (cdr (assoc 1 (entget s)))))
  (and (setq d (car (nentsel "\nDestination: ")))
       (setq d (cdr (assoc 1 (entget d)))))
  (if (and w (or s d))
    (repeat (setq i (sslength w))
      (setq e (ssname w (setq i (1- i))))
      (and s (vl-catch-all-apply 'setpropertyvalue (list e "SOURCE_REFDES" s)))
      (and d (vl-catch-all-apply 'setpropertyvalue (list e "DEST_REFDES" d)))))
  (princ)
Message 7 of 13
jason.lEZRWT
Holy Smokes! That's absolutely perfect! Thank you so much!
Message 8 of 13
ВeekeeCZ
FYI about your original workflow.
Hold CTRL when double-clicking on att to get contextual att editor... a bit faster.
Message 9 of 13
jason.lEZRWT
Just learned that trick this morning. It's a good tip. I need to get in the habit of that one. Just incorporated you program. Works like a charm! Saves a ton of time.
Message 10 of 13
Sea-Haven
Why not do this as 1 line no need for "and",  the description could be more like this.
(setq s (cdr (assoc 1 (entget (car (nentsel "\nPick Source Attribute: "))))))
Message 11 of 13
ВeekeeCZ
The AND prevents the ENTGET from failing when nothing was selected.
Yes, could be more descriptive but why?! It's a very specific tool for this job only.
Message 12 of 13
Sea-Haven
I try to always be descriptive for picks after all the next time it gets ran could be months away and user forgot what to do. Also doing paid work I never know who is going to be using it, including the new kid that started yesterday. I had 8 staff and would occasionally get "how do I run it again"
Any one also reading code can follow the sequence pretty easy.
Message 13 of 13
andkal
Maybe you will also find useful the routine I found >here<. It copies the text content between pointed objects.
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
