@theodore.macaulay wrote:
.... I'm selecting things with my mouse, just a bunch of 2d objects, lines and some arcs basically. then I type REMOVE in the command line and it opens the purge box
REMOVE turns out to be a stand-in alternative command name for PURGE, which means you are typing it in at the Command: prompt, not within an editing command's object selection.
Try either:
A) don't pre-select objects, but first start an editing command [COPY, ERASE, MOVE, CHPROP, or whatever it is you're trying to do with things], and within the object-selection prompting of that command, choose things as you like, and at some point where it's asking you to Select objects:, type in R for Remove [you can type more of the word, but R is all you need]. Remove as a selection option, just as with [for example] Last as a selection option, works only within the Select objects: context, not out in the nothing-happening-yet kind of object pre-selection world. [As a comparison, if you type in L at a Select objects: prompt, you get the Last object, but if you type it in outside that context, including with some objects pre-selected, you get the LINE command and it dumps any pre-selection -- same situation with Remove. If you had typed just R instead of the whole word, you would have gotten REDRAW rather than PURGE.]
or:
B) if you want to do nothing-happening-yet pre-selection of objects, you can remove things by holding the Shift key down while picking things [including with Window/Crossing/Lasso options] to remove from the selection. This also works within an editing command in the Select objects: context.
Kent Cooper, AIA
