Copy a specific attr to an other attr of other blocks
braudpat
Mentor Mentor
Message 1 of 9
braudpat
Hello
I have (and have found) many routines to copy value from attrs to other attrs of other blocks !
But all routines found are testing the Tagname destination attr to be the same !
So I need something slighly different ...
1) Select graphically ONE attribute (from a classic or dynamic Block)
2) Select many other Blocks (classic or dynamic)
3) Ask for the destination attr tagname ...
Which is very often different from the source tagname attribute
4) Copy the value to the N destination blocks which have this specific attribute !
Thanks in advance for your effort !
THE HEALTH, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Replies (8)
Message 2 of 9
pbejse
(defun c:ThisToThat (/ TagSource TagString TagTarget TargetBlocks)
  (if (and
	(setq TagSource (car (nentselp "\nSelect Attribute")))
	(eq "ATTRIB" (cdr (assoc 0 (setq ent (entget TagSource)))))
	(setq TagString (Cdr (Assoc 1 ent)))
	(princ "\nSelect Attribute Blocks to process")
	(setq TargetBlocks (ssget "_:L" '((0 . "INSERT") (66 . 1))))
	(setq TagTarget (strcase (getstring "\nEnter target TAG name: ")))
    (repeat (setq i (sslength TargetBlocks))
      (vl-some
	'(lambda (atb)
	   (if (eq (strcase (vla-get-tagstring atb)) TagTarget)
	     (progn
	       (setq b (vla-get-textstring atb))
	       (Vla-put-textstring atb TagString)
	       (princ
		 (strcat "\nReplaced " b)
	(vlax-invoke
	  (vlax-ename->vla-object
	    (ssname TargetBlocks (setq i (1- i)))
	  'GetAttributes
  (princ)
 HTH
Message 3 of 9
braudpat
Hello @pbejse
THANKS your VLisp Routine is "perfect" !
THANKS again for your fast answer !
THE HEALTH (Stay Safe, Stay Home, Stay Live), Regards, Patrice (The Retired Old French EE Froggy)
Patrice BRAUD
Message 4 of 9
pbejse
You are welcome @braudpat , curious you emphasize Vlips. Are you more comfortable vanilla flavored lisp?
We can write a quick one for that too if needed
Message 5 of 9
braudpat
Hello
I am at level 0.2 in Lisp et level 0.0 in VLisp !
I have programmed with AutoLisp a few years between 1990-1998 and today I have almost all forgotten !!
THANKS, THE HEALTH, Regards, Patrice
Patrice BRAUD
Message 6 of 9
pbejse
FWIW
(defun c:ThatToThese (/ TagSource TagString TagTarget TargetBlocks found blk enx)
  (if (and
      	(setq found nil blk (ssname TargetBlocks (setq i (1- i))))
	    (while
	        (and
	            (null found)
	            (setq blk (entnext blk))
	            (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))
	        (if (= TagTarget (strcase (cdr (assoc 2 enx))))
	            (if (entmod (subst (cons 1 TagString) (assoc 1 (reverse enx)) enx))
	                (progn
	                    (entupd blk)
	                    (setq found TagString)
  (princ)
One must think that coding is like riding a bike... 🙂
I'm sure its still there.
Message 7 of 9
braudpat
Hello
Please is it possible to get a sligthly updated version ?
No question about destination attribut !
Copy directly to the FIRST attribut of destination selected Blocks ...
Thanks, Regards, Patrice
Patrice BRAUD
Message 8 of 9
pbejse
(defun c:HereAndThere (/ TagSource TagString TargetBlocks)
  (and
    (princ (strcat "\n"
		   (itoa (setq i (sslength TargetBlocks)))
		   " item(s) replaced with "
		   TagString
    (repeat i
      (Vla-put-textstring
	(Car (vlax-invoke
	       'GetAttributes
	TagString
  (princ)
(defun c:ThenAndNow (/ TagSource TagString  TargetBlocks found blk enx)
  (and
    (princ (strcat "\n"
		   TagString
    (repeat i
	    (while
	        (and
	            (null found)
	        (entupd blk) (setq found TagString)
  (princ)
HTH
Message 9 of 9
braudpat
Hello @pbejse
THANKS AGAIN ! ... Your second routine is PERFECT !
Patrice BRAUD
