- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi. I have a lot of multileader in this DWG attached (Drawing1.dwg). I need to convert all of them to a certain block I have. I need that the insertion point of the block will be in the same position of the multileader and to copy a part from the text of the leader to the attribute (I need the diameter information in the text and the IL information) . I have attached an example in another DWG attached (Drawing2.dwg). I did it manually of course. Is there a way to make this conversion with a lisp routine?
Thank you all in advance
