Convert DGN files to Autocad 2015 and PDF
GeorgK
Advisor Advisor
GeorgK
Hello together,
whats the best way to convert about 1200 files from DGN to DWG and PDF?
I tried:
   (defun c:Pdf ( / as )
    (setq as (getvar "CTAB"))
    (setq pfad (strcat (vl-filename-directory (getfiled "titel" (strcat (if pfad pfad "") as) "pdf" 1)) "\\"))
    (if as (command "-export" "PDF" "k" "n" (strcat pfad as)))
    (setq as nil)
    (princ)
Thank you very much
Georg
hmsilva
Hi Gerorg.
To convert the DGN files to DWG files, this topic may be a starting point.
Possibly you can modify it to create the the .pdf also.
HTH
Henrique
GeorgK
Hi Henrique,
thank you very much for the link. How could I convert the files to PDF?
Thank you Georg
hmsilva
You're welcome, Georg.
To create the .pdf file, you can use the plot or the export command...
What is the meaning of the "k" option at the -export command?
Henrique
