convert AutoCAD to MicroStation DGN
mruPRQUJ
Message 1 of 28
mruPRQUJ
I wonder if one lisp can be created to convert AutoCAD to MicroStation DGN. If it is possible, I will use ScriptPro to process lots of AutoCAD drawings, thank yolu very much in advance. 🙂
Replies (27)
Message 21 of 28
Jonathan3891
What version of Microstation are you using?
Jonathan Norton
Blog | Linkedin
Message 22 of 28
mruPRQUJ
Message 24 of 28
mruPRQUJ
I can't thank you enough. 🙂
Message 25 of 28
Jonathan3891
You can use Batch Convert to change the dwg files to dgn.
In Microstation Connect > File drop down > Tools > Batch Converter
Edit > Add Files
Defulat Output Format > Dgn
Set your "Default Destination"
Once you've set the format and destination it's important to select all the files and select "Apply to selection"
After that is complete you select "process batch convert job" (right of the red "X" icon)
On the next dialog you select "Convert" and voila.
Jonathan Norton
Blog | Linkedin
Message 26 of 28
mruPRQUJ
Great job, it works well!  Can I ask you one more question? when using MicroStation to convert DGN to DWG , off level will be converted as well. Is it possible to avoid this situation? thanks a million! 🙂
Message 27 of 28
Jonathan3891
I dont know what you mean by off level.
Jonathan Norton
Blog | Linkedin
Message 28 of 28
mruPRQUJ
Off level in MicroStation, like layer off in AutoCAD, thanks
