convert AutoCAD to MicroStation DGN
mruPRQUJ
Message 1 of 28
mruPRQUJ
I wonder if one lisp can be created to convert AutoCAD to MicroStation DGN. If it is possible, I will use ScriptPro to process lots of AutoCAD drawings, thank yolu very much in advance. 🙂
Replies (27)
Message 2 of 28
Moshe-A
@mruPRQUJ  hi,
check DGNOUT commnad (untested)
Note that there are some options to be set, leave it for you 😀
enjoy
Moshe
(defun c:dgnout (/ fname )
 (setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".dgn"))
 ; if file already exist, delete it
 (if (findfile fname)
  (vl-file-delete fname)
 (command "._-dgnexport" "_v8" fname "_Master" "Standard" "")
 (princ)
); c:dgnout
Message 3 of 28
paullimapa
Message 4 of 28
ronjonp
@mruPRQUJ
I'm pretty sure newer versions of Microstation can open DWG files.
Message 5 of 28
Jonathan3891
In my experience dgnout doesnt always work correctly. My recommendation is open Microstation and select File > Import > CAD files. You'd be surprised how well that works!
Jonathan Norton
Blog | Linkedin
Message 6 of 28
mruPRQUJ
I am really sorry to reply to you so late as I am very busy with my work. Thank you very much all of you. The lisp works very well in a single DWG. But when it runs in ScriptPro, some files were failed. Please see attached the screenshot and the failed DWG file, thanks again.
Message 7 of 28
mruPRQUJ
Hi, It looks like the script did not work. I only changed seed file name as I did not have that seed file. Please see the script below, I may make a mistake, thanks a lot!
;Start of routine
-DGNExport
V8
Standard
;End of Routine
Message 8 of 28
paullimapa
looks like this dwg requires 3d seed file which you have to specifically write out in the script:
C:\Users\windows-user-login-profile\AppData\Local\Autodesk\AutoCAD 20##\R##.#\enu\Template\V8-Imperial-Seed3D.dgn
Paul Li
IT Specialist
@The Office
Message 9 of 28
mruPRQUJ
could you please advise me add it to the lisp or script? If it is the lisp, could you please add it to it? I do not know how to add it, thanks a million!
Message 10 of 28
paullimapa
Since the 3d seed is only required on some of the dwg to dgn conversion files but not all you’ll have to  manually convert those dwgs.
Paul Li
IT Specialist
@The Office
Message 11 of 28
Moshe-A
@mruPRQUJ  hi,
Well the problem here is the selected dgn template file. it appears that this drawing need to be converted with a Seed3d template file. if you take "V8-Imperial-Seed3D.dgn"  instead "V8-Imperial-Seed2D.dgn"  it will work but your  problem is there is not command/tool/function that can identify which file is 2d and which need the 3d (at least i could not find)
Moshe
Message 12 of 28
mruPRQUJ
Is it possible to change it to 3D seed file? The first one is for 2D seed file, the second one is for the 3D seed files. Two lisps are used for different files, many thanks. 🙂
Message 13 of 28
Moshe-A
your problem is that you do not know which dwg (to be convert) need Seed3d template?
Message 14 of 28
mruPRQUJ
Do not need to identify them. To use 2D seed file first, to use 3D seed file second time to modify unchanged files, thanks a lot.:)
Message 15 of 28
Moshe-A
say you have a folder with 10 dwg to be convert to dgn.  the 1st is 2d the 2nd is 3d the 3th is 2d... up to last.
the script will stops at the 2nd what good it will do you if you have a second lisp?
Message 16 of 28
mruPRQUJ
Input enter, the script will continue to work. Or it will continue to work automatically, I will try it again later. After modifying 2D seed files, and then using the second lisp to modify 3D seed files, thanks
Message 17 of 28
mruPRQUJ
The scripts work, I may make a mistake before. But I am not sure if it works well with 3D seed files, I will test it later, I can't thank you enough. 🙂
Message 18 of 28
mruPRQUJ
The script only works with 2D seed file, not 3D seed file, many thanks. 🙂
Message 19 of 28
Jonathan3891
Did you try the method I suggested above?
Jonathan Norton
Blog | Linkedin
Message 20 of 28
mruPRQUJ
I know to use MicroStation to convert one DWG to DGN. But how to batch convert them? many thanks, 🙂
