convert 3D solid to 3D faces with LSP program.
Message 1 of 9
I placed a pline to make a box, extrude it to became 3Dsolid, and want to convert 3D solid to 3D faces. I ran codes below, but sometime it converted and other time it didn't. Anyone has a suggestion that I can try?
codes:
 (prompt "\nSelect 3D solid to convert: \n")
 (setq 3D_ENT (car (entsel)))
 (command "convtosurface" 3D_ENT "")
 (vla-SendCommand
    (vla-get-ActiveDocument (vlax-get-acad-object))
    (strcat "UNION" " " "(ssget \"L\")" " " "\r")
 (vla-SendCommand
    (strcat "MESHSMOOTH" " " "(ssget \"P\")" " " "\r")
 (vla-SendCommand
    (strcat "explode" " " "(ssget \"L\")" " " "\r")
Replies (8)
Message 2 of 9
SeeMSixty7
Looking ta your code I think all you want to do is.
(defun c:QUICK()
(setq 3D_ENT (car (entsel "\nSelect Solid")))
(if 3D_ENT ; We are assuming you picked a solid
(progn
(command "CONVTOSURFACE" 3D_ENT "")
(command "UNION" (entlast) "")
(command "MESHSMOOTH" (entlast) "")
(command "EXPLODE" (entlast))
); progn
);if
);defun
good luck
Message 3 of 9
I tested but got same result (like no change/nothing happened at line: (command "MESHSMOOTH" (entlast) "")). I'll check of other solutions. Thanks for taking time to help me out.
[KI]
TONY YANG | CAD PROGRAMMER/ANALYST
P: 920.468.2609 | E: [email protected] | ki.com
[Facebook]
[Twitter]
[Youtube]
[LinkedIn]
[Pinterest]
[Instagram]
[KI - Fixed Seating]
________________________________
As a trusted market resource, KI furnishes more than furniture. We furnish knowledge. www.ki.com
This e-mail, including attachments, is intended solely for the person or entity to which it is addressed and may contain
confidential, privileged and/or proprietary information. Any review, dissemination, distribution, copying, printing, or other
use of this e-mail by persons or entities other than the addressee or his/her authorized agent is prohibited. If you have
received this e-mail in error, please contact the sender immediately and delete the material from your computer.
Message 4 of 9
Ranjit_Singh
I don't know why you need union. Union needs 2 entities. Try this. Create the 3d solid, explode to turn into regions, call meshsmooth to convert regions to mesh and finally call explode again to convert mesh to 3d faces.
Message 5 of 9
marko_ribar
(defun c:QUICK()
(progn
); progn
);if
);defun
good luck
MESHSMOOTH command won't work in (command ...) calls, instead OP guessed correctly by using it inside (vla-sendcommand) call...
Look here for my reply :
https://www.theswamp.org/index.php?topic=52160.msg571599#msg571599
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 6 of 9
Matt__W
Thanks for posting here @marko_ribar (and at TheSwamp). I was hoping I wasn't missing something with regards to the MESHSMOOTH command. Seems I was on the right path all along. Thanks for confirming I wasn't losing my mind.  🙂
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 7 of 9
curro1968
Hello!
I am looking for a LISP to convert 3D solids to 3DFACEs. I cannot use CONTOSURFACE - MESHSMOOTH - EXPLODE because it doesn´t generate 3DFACEs but REGIONs. I need the 3DFACEs (including their INVISIBLE edges) to use them for a dinamic block. In particular, I want to get a dinamic window frame, with their WIDTH and HEIGHT adjustable.
So, if you know any LISP routine to get that, please, tell me. Thanks a lot in advance!
P.S. I attach an example DWG
Message 8 of 9
marko_ribar
Generally speaking, if you get REGIONS up to 4 vertices, you can further EXPLODE it into LINES... Collect 4 different points, remove LINES and create 3DFACES like you wanted - making object stretchable... But I don't quite know why you need assistance, you could have imagined this already very fast...
Message 9 of 9
curro1968
Yes, I knew that...
I needed it to get a 3DFACE surface stretcheable for a dinamic block. I need to explode nothing but making a clone from the 3D SOLID with 3DFACEs and erase the 3D SOLID after that.
If a LISP routine could automatize that process it would be much faster and with no risk of orienting the 3DFACEs in bad mode
That's the Matter!
