Connecting 2 variables to write to a text file
MBestSNZMY
MBestSNZMY
All,
I know this has to be easy....for most.  I haven't figured out the combination yet.
I simply want to connect 2 var's and post them in a text file.  I can do the file part easy.  Connecting these 2 have not been for me.  In vba I can do it but these lines will be in an .scr file.
(setq GetDwgName (getvar "dwgname"))
(setq xLim (getvar "limmax")
(setq FileName (open "D:\\Test Folder\\new_4-20.txt" "w"))
(Setq FText (GetDwgName + " " + xLim))
(write-line (FText) FileName)
(close FileName)
In the text file I want it to read
12345.dwg <space> 11.00 8.00
Mike
paullimapa
Try this
(Setq FText (strcat GetDwgName " " (rtos (car xLim) 2 2) “ “ (rtos (cdr xLim) 2 2)))
Paul Li
IT Specialist
@The Office
mbest
The error:
; error: bad argument type: numberp: (8.5)
paullimapa
oops, my mistake..try this modified:
(Setq FText (strcat GetDwgName " " (rtos (car xLim) 2 2) " " (rtos (cadr xLim) 2 2)))
Paul Li
IT Specialist
@The Office
Kent1Cooper
That line is missing its closing right parenthesis.
Kent Cooper, AIA
Sea-Haven
My attempt
(setq xLim (getvar "limmax"))
(Setq FText (strcat (Getvar 'DwgName) " " (rtos  (car xlim) 2 2) " " (rtos  (cadr xlim) 2 2) ))
or
(rtos  (car (getvar 'limmax)) 2 2) " "
(rtos  (cadr (getvar 'limmax)) 2 2) ))
or
(write-line (strcat (Getvar 'DwgName) " "
filename)
(close filename)
