AutoCAD 2023 Standard Profile Development: How to set the file paths to be on many users local AppData folder?
mnpatric
Message 1 of 18
mnpatric
I need to create a standard profile for all users in a department and include it in the deployment.  The file paths for the departmental standard elements should be on the network locations such as follows:
  • Customized Support Files
  • Enterprise Customization Files
  • Printer Support Files
  • Templates
  • Tool Palettes
However, the file paths below shouldn't be on the network and should be on the users local folders.  These paths are required on the Profile and can't be blank.  If they are not specified, AutoCAD sets the default path.  So what kind of paths I should set on the standard profile?
Replies (17)
Message 2 of 18
Sea-Haven
My automatic save file location is C:/Acadtemp so easy to get to.
If you set up one Pc the do options profiles and save your profile with a new name, then export profile, this will save a ARG file, ok now step 2 copy the desktop icon, right click on copy, go to target and look for say /p "<<C3D_Metric>>" this is a civ3d profile, so change it to /P "yourprofilename" then save the Icon clicking on this icon will run the profile with everything set up, one thing though you have to make the directories seperately. Copy the icon say via email to other pc's and same with ARG file, need to look for where ARG's are saved.
Ok the other way we had a lisp that set everything made directories, set paths, trusted locations, loaded menu's and set up user prefered toolbars. Last item was a script for each user as they all liked different toolbars.
Happy to provide an example. My latest version of an install even unzips files required on a users pc useful for external clients.
Message 3 of 18
mnpatric
No, you misunderstood my question.  I know how to export Profile and set it default on the AutoCAD shortcut.  My question is not just about Automatic Save location.  It's just an example.  Is it generate an error when other users import the profile that contains my local file paths?  If so, how can I add the file paths that direct to all users' AppData folder on their computer?
Message 4 of 18
ronjonp
@mnpatric
(setenv "SaveFilePath" (getenv "TEMP"))
To set many other paths look into:
(vla-get-files (vla-get-preferences (vlax-get-acad-object)))
HERE's some documentation.
The equivalent VLA code for the SaveFilePath would be:
(vla-put-autosavepath (vla-get-files (vla-get-preferences (vlax-get-acad-object))) (getenv "TEMP"))
Message 5 of 18
mnpatric
Please explain your solution in detail. Thank you
Message 6 of 18
ronjonp
@mnpatric I just updated my post .. should help out a bit more.
IMO, importing profiles to other peoples computers has never been a good idea.
Message 7 of 18
mnpatric
how can I create the standard profile for many users?
Message 8 of 18
ronjonp
Depends on what you're changing if you want to do it programmatically. Otherwise export your profile and make sure that there aren't any local paths like in your original question. Open up the *.ARG file in Notepad and do some sleuthing. It could take a bit though, my profile is 3000 lines long.
FWIW, I'd take the programming route.
Message 9 of 18
mnpatric
Some file paths on the Profile requires local path and can't be blank.  How can I distribute the standard profile that I can include in the deloyment?
Message 10 of 18
ronjonp
Define "some file paths". Are paths the only thing that are different from the OOTB profile?
Message 11 of 18
Sea-Haven
Sounds like some directories have not been made, same with files that have not been copied. We pointed to the server so made making a profile so much easier for finding files.
Have a look at attached note the year it was written, current version does way more.
Message 12 of 18
mnpatric
but not all files can't be on the server
Message 13 of 18
mnpatric
Just updated my original post to describe my situation.
Message 14 of 18
ronjonp
@mnpatric Try using %APPDATA% environment variable in the path like so:
%APPDATA%\Autodesk\AutoCAD 2024...
Although I think it defaults to that..
Message 15 of 18
mnpatric
When I use %APPDATA%, the error displays as shown below.  If my path is incorrect, please provide me the correct path that I should use.  Thank you
Message 16 of 18
ronjonp
Try that in the ARG file.
Message 17 of 18
mnpatric
I tried and got the error
Message 18 of 18
ronjonp
I'm sorry, I cannot help you anymore. I've given you some reference files and urged you to use code to set these paths but you have only one solution in your mind and I'm still honestly not clear on your goal.
Maybe someone else with time can pick it up from here. 👍
