Connect all the blocks without going over a polyline
jtm2020hyo
Message 1 of 30
jtm2020hyo
It's possible connect all selected blocks with a polyline but without going over a polyline.?
Accepted solutions (3)
Replies (29)
Message 2 of 30
3wood
Something like this?
LINKPOINTS.
Message 3 of 30
jtm2020hyo
LINKPOINTS.
yes. something like that (in images). I can not make work that file, that vlx file just shows me next window:
...but I need something like that vlx try do.
I attached a lisp routine that works 50% how I need it.
Here is an example of how it works:
...as you can you see some polylines are going over other polylines. What I need is fix that.
Message 4 of 30
jtm2020hyo
I attached 3 lisp-routines that could be useful to make a base
Message 5 of 30
3wood
I guess  the only 2 rules are:
Link all blocks.
No cross over.
Message 6 of 30
ВeekeeCZ
No big ideas in here...
(defun c:BConnectNoX (/ ss pts)
  (if (and (setq ss (ssget '((0 . "INSERT,CIRCLE,POINT"))))
	   (setq pts (mapcar '(lambda (e)
				(cdr (assoc 10 (entget e))))
			     (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
	   (setq pts (vl-sort pts (function (lambda (e1 e2) (< (cadr e1) (cadr e2))))))
	   (setq pts (vl-sort pts (function (lambda (e1 e2) (< (car e1) (car e2))))))
    (entmake (append (list (cons 0 "LWPOLYLINE")
			   (cons 100 "AcDbEntity")
			   (cons 100 "AcDbPolyline")
			   (cons 90 (length pts))
			   (cons 70 0))
		     (mapcar (function (lambda (p) (cons 10 p))) pts))))
  (princ)
Message 7 of 30
jtm2020hyo
Interesting proposal.
apparently, work like Tcount.lsp:
Message 8 of 30
jtm2020hyo
there are more rules that I need add:
+the first rule, the blocks should be linked to the next nearest block no matter rotation or angle.
+the second rule, the LISP routine should work with dynamic blocks and regular blocks. (for some reason 20% of lisp routines that user does not work with dynamic block)
here an example using attached lisp routine (Connect_Blocks-all-option-by-dbhunia.lsp). red-polylines are what I need to fix.
 file, where I tested it, is attached.
Message 9 of 30
dlanorh
If you omit blocks and just consider their insertion points as points, it is a join the dots problem. The problem is Rule 1. It won't allow a solution in most random situations, if it must connect to the next nearest point.
Look at this thread. https://www.theswamp.org/index.php?topic=30434.0
I am not one of the robots you're looking for
Message 10 of 30
jtm2020hyo
the problem is with the next marked blocks...
if possible connect that blocks to their nearest block to their intersections, like this:
...final result should be like this. (connecting all point without going over other)
... final lisp should work with dynamic blocks and regular blocks.
Message 11 of 30
Kent1Cooper
That image now violates the request in Message 1 to "connect all selected blocks with a polyline."  You need to pin down more precisely what you really want to happen.
Kent Cooper, AIA
Message 12 of 30
jtm2020hyo
I was reading that post and I found that they are trying creating geometric figures. that should be a lot more hard to be created. I just need to connect all block or points (base point) without going over other polylines.
Message 13 of 30
jtm2020hyo
yes, you are right.
I just need to connect all points without going over other. no matter how or what to use.
Message 14 of 30
jtm2020hyo
Here I leave an attached lisp created by @dbhunia, might be useful.
this lisp connect selected block with their nearest blocks and have options for limit length.
Message 15 of 30
Kent1Cooper
@jtm2020hyo wrote:
yes, you are right.
Have you seen >this topic< ?
Kent Cooper, AIA
Message 16 of 30
jtm2020hyo
@Kent1Cooper wrote:
@jtm2020hyo wrote:
yes, you are right.
Yes. I already tried but I need to create a link between the nearest blocks.
I tried to use the solution marked in that post but is not what I need, that gives me this:
edit: attached file where I tested your code.
Message 17 of 30
dlanorh
Post your drawing in 2010 format
Message 18 of 30
jtm2020hyo
here is attached my test drawing in 2010 version
Message 19 of 30
jtm2020hyo
Your LinkPoints look interesting, Can you fix your code? or maybe I'm doing something bad? I'm pretty interesting in try to test your code.
Message 20 of 30
jtm2020hyo
I found a lisp-routine that might help to solve this issue. (first attached)
"slbl2" auto-select blocks that are touching selected polylines. simply that.
exactly what we need. now we need to someone to combine it with "Connect_Blocks-all-option-by-dbhunia" lisp-routine. (attached below)
