CompareExport in lisp code
aksel_haeldermans
aksel_haeldermans
I'm trying to export compare to a exportcompare folder.
it is working with the qsave commands.
But it does not work with compare exports.
how do I use to compare export in command line so it does same as the safe commands?
(defun c:bup (/ curfilename CopySaveLocation CurFileName newlen SaveTime mainfilepathname backupfilename savetime mainfilepathcopyname curfilecopyname)
(vl-load-com)
(vl-mkdir (strcat (getvar "dwgprefix") "ExportCompare"))
(setq CopySaveLocation (strcat (getvar "dwgprefix") "ExportCompare"))
(setq CurFileName (getvar "dwgname"))
(setq newlen (- (strlen CurFileName) 10))
(setq CurFileName (substr CurFileName 1 newlen))
(setq UserName (getvar "loginname"))
(setq SaveTime (rtos (getvar "cdate")))
(setq SaveTime (strcat (substr SaveTime 1 4) "-" (substr SaveTime 5 2) "-" (substr SaveTime 7 2) "-" (substr SaveTime 10 6)))
(setq CopyFileName (strcat CurFileName "_WIP-vs-RTC_" SaveTime "_" UserName))
(setvar "filedia" 0)
(setq CurPathCurFileName (strcat (getvar "dwgprefix") (getvar "dwgname")))
(setq CopySaveLocationCopyFileName (strcat CopySaveLocation "\\" CopyFileName ".dwg" ))
(vl-file-copy CurPathCurFileName CopySaveLocationCopyFileName)
;;;  qsave need to be replaced by CompareExport
;;;(command "qsave")
(command "_.CompareExport" "2018" (vl-file-copy CurPathCurFileName CopySaveLocationCopyFileName))
(setvar "filedia" 1)
(princ)
This is not my code I adapted an existing code found on Save DWG file to local backup drive (augi.com)
ВeekeeCZ
And what's the issue? If it's working well with the QSAVE, why it's not an option?
aksel_haeldermans
The drawing that is open is the results of the compare command of 200 drawings based on a template.
The qsave command only saves the current drawing but before saving it drops to compare command so only saves an empty template.
If I use the compareexport commands it includes all the drawings I want to compare, the quick save does not have this function.
ВeekeeCZ
Use this instead of command
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "compareexport\r2018\r" filename "\r"))
aksel_haeldermans
Dear,
it took a while testing.
I tried the next code but no luck.
The results are just below the code.
(defun c:13CompareExport (/ curfilename CopySaveLocation CurFileName newlen SaveTime mainfilepathname backupfilename savetime mainfilepathcopyname curfilecopyname)
(vl-load-com)
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "compareexport\r2018\r" (strcat ".\\" SaveTime " - " (getenv "username") "-" (getvar 'DWGNAME)) "\r"))
(princ)
The result is a dialogbox so = to use the "Compareexport"
(vl-load-com)
(princ)
; error : bad argument type : string nil
(defun c:13CompareExport ()
(princ)
ВeekeeCZ
Yes, obviously. I just used a dummy variable for you to see where to put a file name. Of course, you need to use yours.
