Compare value with list
carlos_m_gil_p
carlos_m_gil_p
Hello boys how are you.
I wanted to ask you, how can I compare a numerical value with a list and know if they are the same or not.
I have two variables.
(setq val 0.0)
(setq lst '(-0.23297 -0.23297 1.0 0.05 4))
val contains the value to compare. This value can be any.
lst contains a list of values, this list can have one or more values.
I need it to return T if all the values of the variable lst are equal to the value of the variable val.
Beforehand thank you very much.
AutoCAD 2026.1.1
Visual Studio Code 1.105.1
AutoCAD AutoLISP Extension 1.6.3
Windows 10 - 22H2 (64 bits)
ВeekeeCZ
Try
(apply '= (cons val lst))
carlos_m_gil_p
Hello brother, thanks for your help, it worked very well.
Greetings.
AutoCAD 2026.1.1
john.uhden
I wrote this earlier today, but something snapped... gone.
Real numbers are not as exact as one might think.
If you are looking for matches that are close enough then
(setq fuzz 0.00001) ;; or whatever you like, then
(vl-every '(lambda (x)(equal val x fuzz)) lst)
John F. Uhden
carlos_m_gil_p
Hello Brother how are you.
I tried your option and it works very well for me.
I think the more exact the better.
I don't know which is better.
AutoCAD 2026.1.1
ronjonp
IMO, use your acceptable tolerance when comparing real numbers.
carlos_m_gil_p
Hello guys, thanks for all the opinions and help, I will take them into account.
Greetings.
AutoCAD 2026.1.1
