Compare two entities if same
paullimapa
Mentor Mentor
Message 1 of 15
paullimapa
Is there a lisp function that would allow me to compare to see if two Entity Names in both cases retrieved using (car(Entsel)) are refer'g to the exact same object in  a given AutoCAD drawing?
Paul Li
IT Specialist
@The Office
Accepted solutions (3)
Replies (14)
Message 2 of 15
hak_vz
Just compare entity handle (code 5).  Handles are unique to each entity
Miljenko Hatlak
Message 3 of 15
paullimapa
Excellent...thanks for the quick reply and solution.
Paul Li
IT Specialist
@The Office
Message 4 of 15
devitg
@hak_vz ,  Handle is unique , and exclusive .
2 equal entities  have different Handle , but ir are equal
So there shall be a way to test for equality.
Message 5 of 15
Sea-Haven
Are they 2
Lines
Same layer
Same angle
Same length
Then yes they are the same but located in different parts of the dwg.
Message 6 of 15
hak_vz
@Sea-HavenI think @paullimapa  asked for exact same object (entity) and not to compare two objects geometric and other properties. Handle is unique object property that stays  saved in dwg as long as it exist in file, while entity name or 1005 xdata change.
Miljenko Hatlak
Message 7 of 15
kpblc2000
(setq a (car (ensel)) b (car (entsel)))
(equal (entget a '("*")) (entget b '("*")))
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
Message 8 of 15
paullimapa
This is another excellent solution...thanks.
Paul Li
IT Specialist
@The Office
Message 9 of 15
devitg
Hi,  , i do not understand  how, 2 "LIKE THE SAME" can give the same entity name .
Only if you pick at the REALLY same ent it will give T for equal.
Neither need to compare the ENTGET. just compare a b
(setq a (car (entsel)))
(setq b (car (entsel)))
(equal a b)
 Will be T if user pick twice at the SAME ent
Maybe the OP , need to know if the user pick twice at the same ENT.
Message 10 of 15
paullimapa
yep, that worked too.
I think my mistake was using the wrong function
I used "=" but that only works for #s
I should be using "equal" which is what works.
Thanks for your input...
Paul Li
IT Specialist
@The Office
Message 11 of 15
Kent1Cooper
[never mind]
Kent Cooper, AIA
Message 12 of 15
Kent1Cooper
[Just for future reference, (=) also works with text strings.  And (eq) works as well as (equal) in this case.]
Kent Cooper, AIA
Message 13 of 15
paullimapa
you are correct...that's why I've used = so much because it also works with strings.
Paul Li
IT Specialist
@The Office
Message 14 of 15
paullimapa
found this thread of another using = instead of equal
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/compare-entity-names/td-p/2422897
Paul Li
IT Specialist
@The Office
Message 15 of 15
devitg
My not-twice way
(SETQ A (CAR (ENTSEL)))
(SETQ OTHER (NOT-TWICE A))
(DEFUN NOT-TWICE  (A / B)
  (SETQ B (CAR (ENTSEL)))
  (IF (EQUAL A B)
    (PROGN
      (ALERT "you pick the same entity")
      (NOT-TWICE A)
  B
