Compare and Merge Layers
Hi all,
i am new to AutoCAD AutoLISP.  I have a problem that I cannot solve on my own.
Is there any way to Automate following process using a Macro / AutoLISP file?
There are multiple layers with standardized names.
E.g.:
Arch1_TXT_NEW
Arch1_TXT_STOCK
Bul1_CMS_NEW
Bul1_CMS_STOCK
Is there any way i can wirte a script that compares the layer names, then if it finds a matching pair where the difference is only the text "NEW" and "STOCK" and applies to all elements in the layer "NEW" the layer "STOCK", iterating through all layers and then cleaning the empty "NEW" layers with a purge command?
I would be really thankful if somebody could guide me how to do this. Also, if if my text is incomprehensible, please draw my attention to it, i am not a native english speaker.
Kind regards,
Robert
ВeekeeCZ
Robert, welcome to the Forums,
try this LISP to see if it works for you.
BTW it's never too late to learn at least some basics of programming. Plenty of people came here to help with learning.
(defun c:MergeNewToStock ( / d o n)
  (while (setq d (tblnext "LAYER" (null d)))
    (setq o (cdr (assoc 2 d)))
    (if (and (wcmatch o "*_NEW")
	     (setq n (strcat (substr o 1 (- (strlen o) 3)) "STOCK"))
	     (tblsearch "LAYER" n)
      (command "_.LAYMRG" "_Name" o "" "_N" n "_Y")))
  (princ)
Its works very well and the script looks insanely elegegant and short, coud you recommend me ressources to learn such things? I am really willing to learn and if i get better even to help out in the community!
Thanks alot for your help!
ВeekeeCZ
Glad to hear that.
Two links for you, ONE  and the SECOND
Btw, it's called a LISP. Word "script" has its specific meaning in AutoCAD and it's *.scr file with a sequence of autocad's commands directly working with the command-line.
