command with lisp load in conditional -bedit
robert06
robert06
I can't figure this out, after adding condition to check if the block exists in drawing, the 'csdf' command from "Convert_SaveDate_Fields_CSDF.lsp" won't execute as expected in the lisp:
Command: -bedit
Enter block name or [?]: blockname Regenerating model.
Regenerating model.
Command: Regenerating model.
Command: bsave
Command: bclose Regenerating model.
Command: ; error: bad function: C:CSDF
(if (tblsearch "block" "blockname")
(progn ((command "-bedit" "blockname")
(load "Convert_SaveDate_Fields_CSDF")
(c:csdf)
(command "bsave")
(command "bclose")
berfore:
(c:csdf)
(command "bsave")
(command "bclose")
hmsilva
Hi Robert,
you have an extra pair of () brackets inside progn function, try
   (progn (command "-bedit" "blockname")
          (c:csdf)
          (command "bsave")
          (command "bclose")
Hope this helps,
Henrique
robert06
Thank you!
hmsilva
You're welcome, robert06
Glad I could help
Henrique
