(command "spline") vrs command line "spline"
martin.mardikas
martin.mardikas
Hi!
I try to write .lsp routine and use command(command "._spline"). But it seems to run a bit differently if I run spline command in AutoCAD command line.
What seems to be the difference.
ВeekeeCZ
That's very common.
The LISP version is usually an older version of the current AutoCAD version.
In LISP you can usually use (initcommandversion) predecessor to enforce the current AutoCAD version.
(progn (initcommandversion) (command-s "spline"))
martin.mardikas
Thank you, that works!
