(command "qleader") does not offer settings on command line
JamesMaeding
Advisor Advisor
Message 1 of 14
JamesMaeding
How do I get this to show, like when you type qleader straight on command line:
Specify first leader point, or [Settings] <Settings>:
I simply want to make a key-in with lisp like:
(DEFUN C:Q    () (command "qleader"))
but that gives no settings option on command line....
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Replies (13)
Message 2 of 14
paullimapa
Works for me when I run the same sequence.  What happens if you include the Settings input in the code, would it work?
(DEFUN C:Q    () (command "qleader""settings"))
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 14
JamesMaeding
well, S does give the settings but the users cannot see that as an option.
I want the key-in Q to do exactly the same thing as QLEADER, and I will not be using the pgp file for this.
Message 4 of 14
Ranjit_Singh
Maybe check the cmdecho and nomutt variables?
Message 5 of 14
lando7189
Refer to R Robert Bell's response here -- there is a QLSET.lsp file that should get you what you need.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/setvars-for-qleader-variables/m-p/16...
Message 6 of 14
JamesMaeding
@lando7189
Thanks, but I saw that and is not related to what I am asking.
Maybe re-read my original post.
I also tried cmdecho, nomutt....no go.
thx
Message 7 of 14
lando7189
Sorry about the misread... try this:
(defun C:Q ( / q_err old_err pt nomutt cmdecho)
  (if (setq pt (getpoint "\nSpecify first leader point... "))
    (progn
	  (defun q_err (s)
	    (if (/= s "Function cancelled")
	      (progn
	       (princ (strcat "\nError: " s))
	    (setq *error* old_err)
	    (setvar "NOMUTT"  nomutt)
        (setvar "CMDECHO" cmdecho)
      (setq old_err *error* *error* q_err)
      (setq nomutt  (getvar "NOMUTT"))
      (setq cmdecho (getvar "CMDECHO"))
      (setvar "NOMUTT"  1)
      (setvar "CMDECHO" 0)
      (command "QLEADER" pt)
  (princ)
Message 8 of 14
Ranjit_Singh
OK. Try using command-s instead of command.
(DEFUN C:Q () (command-s "qleader"))
Message 9 of 14
ВeekeeCZ
Why? LISP might give you a different command or you might lose some functionality (eg. preview).
Try it with (prince) at the end... nil might cause a trouble...
(DEFUN C:Q    () (command "qleader") (princ))
Message 10 of 14
lando7189
Ahh... i have never used command-s yet myself (i try to avoid command line usage in most of my own stuff).  That actually avoids having to use an error catcher my lisp command (it is your solution, but using a 'getpoint' to avoid the 'blank' command line)
(defun C:Q ( / pt)
    (command-s "QLEADER" pt)
  (princ)
Message 11 of 14
JamesMaeding
Well this is definitely entertaining, but I don't think anyone is testing their ideas, none work.
I had already tried all of them anyway, I've done lisp forever and typically its some initget needed for calling from lisp (command... statement.
There is some devilry going on with qleader that I have not seen before.
Message 12 of 14
Ranjit_Singh
........but I don't think anyone is testing their ideas, none work........
Post #8 clearly shows how it works on my system. Even testing @ВeekeeCZ's suggestion worked at my end. See below.
If both of those options don't work on your system then we can safely conclude that the problem is in your system, and not with qleader. I believe even @lando7189 confirmed that one of those options worked on his systems. Maybe test on a different workstation. Good luck.
Message 13 of 14
Kent1Cooper
@Ranjit_Singh wrote:
OK. Try using command-s instead of command.  ....
That "shouldn't" work, because [from 2018 Help] "The command that is being executed must be started and completed in the same command-s function."
If, as it appears from your video clip, it will  in fact leave you in the command if you don't supply everything to complete it, I don't see any advantage over just plain (command).  That worked for me, offering the Settings option the OP is looking for, both on its own and when defined into a command name with (defun).  So if it doesn't for them, there must be something else going on, as suggested in Post 12.
Kent Cooper, AIA
Message 14 of 14
JamesMaeding
I see, I was turing on cmdecho , then right off in a little function I use to print the command desc to the command line, duh.
Good call, CMDECHO to 1 is the answer.
We see yet again why the first letter of Lisp stands for lost 🙂
