Command offset multiple times on same side
Message 1 of 13
I have created a lisp where you select a line, choose a point to offset on, and multiple lines are created.
 (if
   (and (setq ss (ssget "_+.:S:L" '((0 . "*POLYLINE,*LINE,CIRCLE,ELLIPSE"))))
        (setq p (getpoint "\nSpecify point:"))
    (progn
      (command "_.offset" 0.5 ss "_non" p "")
      (command "_.offset" 0.625 (ENTLAST) "_non" p "")
      (command "_.offset" 5.5 (ENTLAST) "_non" p "")
If the point chosen is passed by the multiple lines created, the the lines would offset going the opposite direction (back towards the point). I know this is how it is supposed to work, but I am wondering if there is a way to make all the lines offset going in the same direction. Any help would be greatly appreciated. Thanks!
Replies (12)
Message 2 of 13
dlanorh
It would probably be better putting it in a loop and pass in a list of distances
(if
        (setq p (getpoint "\nSpecify point:") dst 0)
    (progn
      (setq lst (list 0.5 0.625 5.5))
     (foreach d lst
        (setq dst (+ d dst))
        (command "_.offset" dst ss "_non" p "")
     );end_foreach
   );end_progn
);end_if
I am not one of the robots you're looking for
Message 3 of 13
Hi dlanorh. Your code works well and can do what I was asking. However, I don't think I can use the loop because I am using command chprop to change the layer of the lines inbetween each offset command. Do you know a way without using a lisp, if that would be possible.
Thanks so much for helping me though. I will be using your code to see if it works with what I have.
Message 4 of 13
dlanorh
You can change the layer property of each line within the loop if that is required. Do the offset distances correspond to layers i.e. if the offset is 0.5 will the layer name of that line alway be the same? If not, it is possible to collect the distances and corresponding layers prior to execution.
It is also possible, if required, to offset both sides without having to select a side.
Message 5 of 13
No, the offset distances do not correspond to layers. I was thinking of doing what you suggested, creating a list of layer names as well, but I am not sure how to code it.
What I was thinking with the for loop could be doable in other languages
dist = [1,2,3,4]
layer=[a,b,c,d]
for i in range (0,4,1):
 offset dist[i] ...
 chprop layer[i] ...
Obviously this code is not correct, but I was wondering if there was a way to use the index in a list instead of the actual value.
Message 6 of 13
CodeDing
@Anonymous ,
Here is a way to offset both sides
(if (setq ss (ssget "_+.:S:L" '((0 . "*POLYLINE,*LINE,CIRCLE,ELLIPSE"))))
  (progn
    (setq dLst '((0.5 . "LyrA") (1.125 . "LyrB") (6.625 . "LyrC")))
    (repeat (setq cnt (sslength ss))
      (setq e (ssname ss (setq cnt (1- cnt))))
      (foreach d dLst
	(vla-offset (vlax-ename->vla-object e) (car d))
	(setq el1 (entlast))
	(vla-offset (vlax-ename->vla-object e) (- (car d)))
	(setq el2 (entlast))
	(if (setq lyr (tblobjname "LAYER" (cdr d)))
	  (progn
	    (setpropertyvalue el1 "LayerID" lyr)
	    (setpropertyvalue el2 "LayerID" lyr)
	  );progn
	  (prompt (strcat "\n...Layer \"" (cdr d) "\" not found."))
	);if
      );foreach
    );repeat
  );progn
);if
Hope that helps
~DD
Message 7 of 13
Codeding I am not trying to offset on both sides. I want to be able to make it so that the side a line is offsetted on is the same for all the lines. Thanks though.
Message 8 of 13
Kent1Cooper
How about just Offsetting the same original  each time, but summing up the distances for each one?  The point will always be on the right side, even when the result overshoots it.
      (command "_.offset" 1.125 ss "_non" p "")
      (command "_.offset" 6.625 ss "_non" p "")
Kent Cooper, AIA
Message 9 of 13
dlanorh
Two way to achieve what you require using 2 lists and a list of lists. There is a purely vl lisp way of doing it as well
(defun c:o1 ( / ss p o_lst l_lst cnt dst lyr)
(if
    (progn
      (setq o_lst (list 0.5 0.625 5.5)
            l_lst (list "1" "2" "3")
            cnt 0
     (while (< cnt (length o_lst))
        (setq dst (+ (nth cnt o_lst) dst)
              lyr (nth cnt l_lst)
        (vlax-put-property (vlax-ename->vla-object (entlast)) 'layer lyr)
        (setq cnt (1+ cnt))
     );end_foreach
   );end_progn
);end_if
(vl-load-com)
(defun c:o2 ( / ss p o_lst dst lyr)
(if
    (progn
      (setq o_lst (list (list 0.5 "1") (list 0.625 "2") (list 5.5 "3"))
     (foreach d o_lst
        (setq dst (+ (car d) dst)
              lyr (cadr d)
     );end_foreach
   );end_progn
);end_if
Message 10 of 13
CodeDing
hahaha
@Kent1Cooper , that is where my mind was, but I was going down a rabbit hole!!! Was trying to incorporate vla-offset, but could not FOR THE LIFE OF ME figure out how to handle clockwise/counterclockwise polylines. UGHH.
K.I.S.S.
~DD
My painful rabbit hole accomplished nothing:
(defun off-test (e p / p2 ang)
(setq p2 (vlax-curve-getclosestpointto e p t)
      ang (angle p2 p))
 (if (< pi ang (* pi 2)) t nil)
);defun
(if (and (setq ss (ssget "_+.:S:L" '((0 . "*POLYLINE,*LINE,CIRCLE,ELLIPSE"))))
	 (setq p (getpoint "\nSpecify point: ")))
  (progn
      (setq e (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))))
      (foreach d dLst
	(if (off-test e p) (setq d (cons (- (car d)) (cdr d))))
	(vla-offset e (car d))
	(setq el (entlast))
	  (setpropertyvalue el "LayerID" lyr)
	);if
      );foreach
    );repeat
  );progn
);if
Message 11 of 13
Thanks dlanorh. I used your first solution and it worked very well. Thanks to everybody else for helping as well.
Message 12 of 13
Sea-Haven
Just my $0.05 a multi offset done previously works by just entering text with multiple offsets -ve values mean go left.
eg input 2,3,4,-2,-3,-4 would do offsets both sides. at 2, 3, 4.
Trying to find it possibly posted at Cadtutor. Could add like current layer plus offset as name.
Message 13 of 13
kibitotato
This thing is what exactly I need to save tons of time right now... but I´m not able to make it works...
Autocad said it to me
Precise distancia de desfase o [punto a Atravesar/Borrar/Capa] <0.5000>: 0.5
Designe objeto a desplazar o [Salir/Deshacer] <Salir>:
Precise punto en lado de desplazamiento o [Salir/Múltiple/Deshacer] <Salir>: _non
Comando: ; error: Error de automatización. Clave no encontrada
translate
Specify offset distance or [point to Traverse/Delete/Layer] <0.5000>: 0.5
Specify object to move or [Exit/Undo] <Exit>:
Precise point on offset side or [Exit/Multiple/Undo] <Exit>: _non
Designate object to move or [Exit/Undo/Exit] <Exit>:
Command: ; error: Automation error. Key not found
some help please? whats wrong???
