Command macro explode all, set properties and purge all
Hi all
I'm trying write a command with a macro that:
first explode all( 3 times to be sure that all is exploded)
then change properties of all objects (color/layer/linetype)
and at the end purge all (3 time to be sure that all is purged)
^C^C^C_ai_selall;_explode;_ai_selall;_explode;_ai_selall;_explode;_ai_selall;_chprop;color;5;layer;0;ltype;continuous;_purge;all;*;n;_purge;all;*;n;_purge;all;*;n;
but don't work 😞
It's interrupt during the second selection request.
if i split this in many different macros works,but in a single string no.
help please
Moshe-A
@Anonymous  hi,
except for getting exploded blocks you turn all polylines to lines and mtext to text, just to understand, what's the point in doing that???
moshe
Also for modify something and also for other software the work with the file next.
The problem with the macro is on the selection. I don't understand why don't work many time the same command,and also if the explode command don't find anything to explode the macro don't work. I don't know how many time I have to make explode to be sure that all is exploded, sometimes also 1... But rarely also 2 o 3.
Sorry for bad English.
Moshe-A
@Anonymous
how about that?
plot the dwg to pdf than convert it back >> to dwg here <<
much easier
moshe
pendean
Community Legend
Community Legend
Classic ancient tip:
set up a DXB plotter then plot to it with the parameters you want.
Open a blank DWG file, then DXBIN command.
Your new file is now total garbage (aka your intent).
