Command line results to Message box
David_Prontnicki
Message 1 of 9
David_Prontnicki
Is it possible to take the results from a command line command and place them in a message box? For example, the command, LISTAVAILABLEPOINTNUMBERS will display the results in the command line. I would like to take those results and have an alert display them.
Thank you
Replies (8)
Message 2 of 9
Kent1Cooper
[I assume that's a Civil3D function, since it's not in native AutoCAD.]  Do you know whether it also puts its findings into anything like a variable, from which they could be extracted to put into an (alert) message?
Kent Cooper, AIA
Message 3 of 9
David_Prontnicki
Yes it is a Civil 3D command, and unfortunately no I don't know if it puts its finding into a variable. I have been looking for where the command originates from to see but with no luck.
Message 4 of 9
ВeekeeCZ
How about something simple:
(defun c:ListAvailablePointNumbers! nil
  (command "ListAvailablePointNumbers")
  (alert (substr (getvar 'LASTPROMPT) 1)) ; change 1 to 26 if you want to show the range only.
  (princ)
You may post C3D related questions rather  HERE
Message 5 of 9
David_Prontnicki
BeekeeCZ,
Simple is always better. Sometimes you overthink things. 🙂 It seems so obvious now. LOL.
Real quick so I understand whats going on:
1 - shows the range only
26 - shows nothing
Thank you so much!!!!
Message 6 of 9
ВeekeeCZ
26 - shows nothing
No. At least not to me. This is what is listed to my command-line:
Command: LISTAVAILABLEPOINTNUMBERS!
ListAvailablePointNumbers 1-4294967294
Routine then takes a part of the second line starting char number (1 or 26) to the end. So 1 is the whole second line, 26 is just a range. (word "ListAvailabelPointNumbers" has 26 chars or so)
Message 7 of 9
David_Prontnicki
OK got it. For me the issue is my command line displays like this:
So there is nothing at the 26th char.
Thank again!
Message 8 of 9
ВeekeeCZ
I guess you have 'cmdecho off.
Message 9 of 9
David_Prontnicki
Yes that's what it is. So I added get current cmdecho, set to off, and restore previous. Since I don't know what each person has it set to. That way I can just keep it set to one.
Thank you again for all your help.
