Command line button
Command line button
davidlanesmith673
Message 1 of 8
Command line button
davidlanesmith673
I was wondering if there is a way to add buttons to your own commands that show up in the command line, like in PEDIT where there is the OPEN, JOIN, WIDTH... options that you can click:
Accepted solutions (3)
Replies (7)
Message 2 of 8
ВeekeeCZ
Sure, like this...
(defun c:TestYourPedit ()
  (initget "Open Join Width")
  (getkword "PEDIT Enter an option [Open/Join/Width]: ")
Message 3 of 8
davidlanesmith673
Thanks, exactly what I need!!
Message 4 of 8
You can also specify a default selection, like this:
(getkword "PEDIT Enter an option [Open/Join/Width]<Join>: ")
Message 5 of 8
davidlanesmith673
I tried that, and I seems to be more complicated than just adding <Join> at the end.
Message 6 of 8
pbejse
(initget "Open Join Width");<-- this allows the user to press enter without entering a keyword
(Setq opt (getkword "PEDIT Enter an option [Open/Join/Width]<Join>: "))
(setq opt (if (null opt) "Join" opt));<-- if user pressed enter, Join will be the default
Command: TESTYOURPEDIT
PEDIT Enter an option [Open/Join/Width]<Join>: user pressed enter
"Join"
PEDIT Enter an option [Open/Join/Width]<Join> : w
"Width"
If you include 1 on the initget line  (initget 1 "Open Join Width") The user is force to select among the choice
PEDIT Enter an option [Open/Join/Width]: user pressed enter
Invalid option keyword.
Message 7 of 8
Kent1Cooper
You can also, if you like, have it offer your prior choice as default on subsequent use, so you can use Enter/space to accept that, instead of typing/picking it again, similar to the way many AutoCAD commands work.  And you can have an initial default to offer, or not.  This is a way if you want an initial default offered on first use:
  (setq opt ; must be a global [not localized] variable to remain available on subsequent use
    (cond
      ( (getkword ; <-- returns nil on Enter
          (strcat
            "PEDIT Enter an option [Open/Join/Width] <"
            (cond (opt) ("Join")); <-- prior choice as default if present, otherwise Join
          ); strcat
        ); getkword
      ); end User-input condition
      (opt); <-- prior choice on Enter, if present
      ("Join"); <-- initial default on Enter at first use
    ); cond
  ); setq
  .... whatever ....
); defun
This is a way if you don't want an initial default offered, but want to require the User to specify the first time:
  (initget (if opt 0 1) "Open Join Width"); <-- allows Enter only if there's a prior choice
  (setq opt
    (cond
      ( (getkword ; <-- returns nil on Enter [only when permitted]
          (strcat
            "PEDIT Enter an option [Open/Join/Width]"
            (if opt (strcat " <" opt ">") ""); <-- offers prior choice default only if present
          ); strcat
        ); getkword
      (opt); <-- prior choice on Enter when permitted
    ); cond
  ); setq
  .... whatever ....
); defun
Kent Cooper, AIA
Message 8 of 8
davidlanesmith673
Ok, yah that makes sense. Before I had included 1 on the initget line.
