Command Issues
Command Issues
Command Issues
My snap settings are getting unchecked whenever I enter my WA(Wiring Arc) command. I cant snap onto anything once I enter this command. Is there a way to keep my snaps all checked regardless of whatever command I am typing?
Thank you.
Patchy
There is no WA command to do Wiring Arc that came with plain Autocad.
Ask the correct discussion group for help.
If it's an add-on command, ask the customization group.
imadHabash
>> My snap settings are getting unchecked whenever I enter my WA(Wiring Arc) command <<
usually this happened if you're using a kind of plug-in or lisp to use through AutoCAD.it's clear that WA not an autocad command.
Imad Habash
Yes it is a lisp which i copied from this group. So now I need to know how do I retain my snaps when I use this WA command?
imadHabash
Then.. you need some one who has good experience in writing lisps to modify it for you.i suggest to post your need here >> Lisp << .
Good Luck..
Imad Habash
Kent1Cooper
.... If it's an add-on command, ask the customization group.
[It came from here, and they've raised the question on that thread.]
Kent Cooper, AIA
Patchy
My thought was it could be autolisp or OP is using Autodesk Electrical app.
