Command: GROUP not the same as (command "GROUP")
R2016
I want this:
Command: GROUP Select objects or [Name/Description]:
However, this is what I have been able to find for LISP:
Command: (command "GROUP") GROUP Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: Command: (command "Group") Group Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: Command: (command "-Group") -Group Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: Command: (command ".Group") .Group Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>:
Is there a trick to getting what I want?
Did I miss something?
The "Create" method prompts for name and description.
I do not want the prompt for description.
scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
