Command: GROUP not the same as (command "GROUP")
scot-65
Advisor Advisor
scot-65
R2016
I want this:
Command: GROUP Select objects or [Name/Description]:
However, this is what I have been able to find for LISP:
Command: (command "GROUP") GROUP Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: Command: (command "Group") Group Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: Command: (command "-Group") -Group Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: Command: (command ".Group") .Group Enter a group option [?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>:
Is there a trick to getting what I want?
Did I miss something?
The "Create" method prompts for name and description.
I do not want the prompt for description.
scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
paullimapa
You can always code in exactly what you want using quotes "" to represent an enter command:
(command "group" "" "groupname" "")
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
trevor.bird.au
Hi Scot,
Does this help:
Command: (initcommandversion)
Trevor
Moshe-A
Scot-65,
set QAFLGAS to 1.
i know you here for long time helping others maybe be you even helped me some time and i would like to thank you on behalf of all others
now i got the chance to return you with small tip Smiley Very Happy
thanks
Moshe
paullimapa
excellent...QAFLAGS set to 1 also works...great job!!!
Paul Li
IT Specialist
@The Office
