collect coordinates as a list
hi
I'm sure this has been answered before, but with the news group in its
current state of where ever land, I'm posting the question again.
How do I store coordinates in a list so that I can retrieve them later. I'm
wanting to store the coordinates as they are entered. and then use that data
to replace a line with a leader or find the angle between two points etc.
The best I managed (with my limited list experince) was saving the points
more as a string rather than a point. This works fine for the drawing a new
line but didn't work for finding the angle between two points contained in
the list.
I guess I'm going about it wrong.
Any help or clues would be appreciated.
thanks
CJ Follmer
There's probably a better way but this should get you started:
;;; Returns a list of points selected by the user
(defun collect-points (/ pt lst)
(setq pt T)
(while pt
(if lst
(setq pt (getpoint (car lst) "\nSelect point: "))
(setq pt (getpoint "\nSelect point: "))
(if pt
(setq lst (cons pt lst))
(reverse lst)
Get free software and more at http://www2.stonemedia.com/franko
"CJ Follmer" wrote in message
news:eee1eec.-1@WebX.SaUCah8kaAW...
> hi
I'm
data
new
> the list.
> thanks
> CJ Follmer
In LISP, 3D points are stored as a list of three doubles.
You can create a list of points using the (cons) or (append)
functions.
For example (using cons):
(while (setq p (getpoint "\nEnter point: "))
(setq point_list (cons p point_list))
This causes each point entered to be added to the
list assigned to 'point_list', in the reverse order
which they were supplied.
You can use the (reverse) function to put the points
in the same order they were entered:
(setq point_list (reverse point_list))
You can process the list of points one point at a
time, using (foreach), like this:
(foreach point point_list
(print point) ;; print it out
You can draw a line through all of the points in
the point list, like this:
(command "._LINE")
(apply 'command point_list)
(command "")
CJ Follmer wrote:
> hi
> the list.
> thanks
> CJ Follmer
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
thanks guys
I'll give it a try.
Just got the NG back on my news reader AGAIN!
very frustrating.
Thanks guys, got it to work like a charm.
