Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
code to create 3DPOLY from 3D LINes
autoid374ceb4990
Message 1 of 40
autoid374ceb4990
I have a routine that creates a series of 3d LINEs for the boundary of a group of 3DFACEs.
Does anyone have an autoLisp (not visual lisp, I am using R14) that would join the 3D LINEs into  a 3D POLYINE?  The 3D LINEs are not in any order.
Replies (39)
Message 2 of 40
Sea-Haven
A couple of ideas, this expects that all the lines are in same direction and in sequence.
(defun c:wow ( / ss lst ent pt)
(setq ss (ssget '((0 . "LINE"))))
(setq lst '())
(repeat (setq x (sslength ss))
  (setq ent (entget (ssname ss (setq x (1- x)))))
  (setq  lst (cons (cdr (assoc 10 ent)) lst))
(entmake '((0 . "POLYLINE") (70 . 9)))
(foreach pt lst (entmake (list '(0 . "VERTEX") '(70 . 32) (cons 10 pt))))
(entmake '((0 . "SEQEND")))
(princ)
A good idea is post a sample dwg use say WBLOCK to export your 3d lines.
Message 3 of 40
autoid374ceb4990
Well the lines are not in the same direction and not in sequence, if you define sequence as created sequentially.  drawing attached.
Message 4 of 40
chriscowgill7373
It is unfortunate that you are stuck on almost 30 year old software. The JOIN command would be able to handle it in newer versions. Have you tried the PLJOIN Bonus tool to make sure it didnt work?
Couldnt you just select all the lines, obtain the list of coordinates, sort that list and the remove duplicates and start the command feeding the filtered list into it?  Or, were those functions not available in R14?  It is very difficult to look at a task like this because it cant be tested.  Maybe it works similar to lisp in LT or in MAC, so someone with one of those software might be able to write a code and test it.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 5 of 40
autoid374ceb4990
You are probably correct.  I have found several PLJOIN type lisp routines, but of course they will not work with my old R14. Guess I will have to write my own.
Message 6 of 40
marko_ribar
Here, try these 2 variants... First one should be much faster... Untested though (quickly written)...
(defun c:lins23dpoly ( / ss i lil lix liln li lii )
  (if (setq ss (ssget (list (cons 0 "LINE"))))
    (progn
      (repeat (setq i (sslength ss))
        (setq lil (cons (list (cdr (assoc 10 (setq lix (entget (ssname ss (setq i (1- i))))))) (cdr (assoc 11 lix))) lil))
      (setq liln (cons (car lil) liln))
      (while (setq li (car lil))
        (setq lil (cdr lil))
        (setq lii (vl-some (function (lambda (x) (if (or (equal (cadr li) (car x) 1e-8) (equal (cadr li) (cadr x) 1e-8)) x))) lil))
        (cond
          ( (and lii (equal (cadr li) (car lii) 1e-8))
            (setq liln (cons lii liln) lil (cons lii (vl-remove lii lil)))
          (  lii
            (setq liln (cons (reverse lii) liln) lil (cons (reverse lii) (vl-remove lii lil)))
      (entmake (list (cons 0 "POLYLINE") (cons 70 9)))
      (foreach pt (mapcar (function car) liln)
        (entmake (list (cons 0 "VERTEX") (cons 70 32) (cons 10 pt)))
      (entmake (list (cons 0 "SEQEND")))
  (princ)
(defun c:lins23dpoly-vanilla ( / _reverse _vl-some _vl-remove ss i lil lix liln li lii )
  (defun _reverse ( lst / r )
    (while lst
      (setq r (cons (car lst) r))
      (setq lst (cdr lst))
    r
  (defun _vl-some ( fun lst / func el r )
    (setq func (eval fun))
    (while (setq el (car lst))
      (if (setq r (func el))
        (setq lst nil)
    r
  (defun _vl-remove ( el lst / e r )
    (while (setq e (car lst))
      (if (not (equal e el))
        (setq r (cons e r))
    (_reverse r)
    (progn
        (setq lii (_vl-some (function (lambda (x) (if (or (equal (cadr li) (car x) 1e-8) (equal (cadr li) (cadr x) 1e-8)) x))) lil))
        (cond
            (setq liln (cons lii liln) lil (cons lii (_vl-remove lii lil)))
          (  lii
            (setq liln (cons (_reverse lii) liln) lil (cons (_reverse lii) (_vl-remove lii lil)))
  (princ)
HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 7 of 40
autoid374ceb4990
HTH.
M.R.
I appreciate the effort, but as stated in my original post,  I am usingR14, NO VL functions.  The AI websites have the same reaction.
Message 8 of 40
leeminardi
@marko_ribar
Tested it and got
lee.minardi
Message 9 of 40
marko_ribar
Thanks for reporting bug... Now fixed...
M.R.
Message 10 of 40
autoid374ceb4990
HTH.
M.R.
I tried the vanilla version in R14.  Seems to work correctly down to this line:
Gives me: "ACAD error: null function"
Message 11 of 40
Sea-Haven
@marko_ribar worked fine in Bricscad, is the problem (_vl-some which may not be in R14 being a VL function.
My biggest suggestion would be maybe look at upgrading software to something more current, Bricscad Lite has lisp. There are others.
Message 12 of 40
marko_ribar
Here, I changed just slightly (_vl-some) function and line with (_vl-some) in routine body... It worked on my BricsCAD...
    (while lst
    r
  (defun _vl-some ( fun lst / el r )
      (if (apply fun (list el))
        (setq r el lst nil)
    r
        (setq r (cons e r))
    (_reverse r)
    (progn
        (setq lii (_vl-some (function (lambda (x) (or (equal (cadr li) (car x) 1e-8) (equal (cadr li) (cadr x) 1e-8)))) lil))
        (cond
          (  lii
  (princ)
HTH.
M.R.
Message 13 of 40
autoid374ceb4990
HTH.
M.R.
Still getting "null function" at this line:
Not getting to the "_vl-some" routine.
I am no expert lisp programmer, but could it be that the "function" call is not supported in my old R14?
Don't worry about this problem.  I will write a "C" program that works in R14.
Message 14 of 40
marko_ribar
@autoid374ceb4990 wrote:
HTH.
M.R.
That is possible... Your AutoCAD is too old, but I prepared this mod. that may succeed... Please, test it now... It also worked on my BricsCAD...
(defun c:lins23dpoly-vanilla-foo ( / _reverse _foo _vl-remove ss i lil lix liln li lii )
    (while lst
    r
  (defun _foo ( li lst / el r )
      (if (or (equal (cadr li) (car el) 1e-8) (equal (cadr li) (cadr el) 1e-8))
        (setq r el lst nil)
    r
        (setq r (cons e r))
    (_reverse r)
    (progn
        (setq lii (_foo li lil))
        (cond
          (  lii
  (princ)
HTH.
M.R.
Message 15 of 40
autoid374ceb4990
HTH.
M.R.
Tried it, same error.
And for everyone that has suggested upgrading my AutoCAD - NOT going to do that. I am a retired civil engineer and land surveyor and I wrote all the software starting with AC 9 that I used in my business.  I even still have an old HP 7580B pen plotter.  Got tired of having to buy a new compiler every time AutoCAD upgraded, plus I did not like their "lend-lease" pricing policy.  End rant.
Message 16 of 40
Sea-Haven
I run lisp code I wrote back in the 80's on current Acad and Bricscad, with no code changes. You refer to compiler did you also do some ADS coding ?
Bricscad can be purchased as perpetual.
Message 17 of 40
autoid374ceb4990
When I started in business I purchased an Apple II and started writing my business software in interpreted Basic.  Then Apple brought out the Macintosh, and you had to purchase a $6000 Lisa machine to program the Mac.  I switched to the IBM PC and converted all my Apple stuff to "C".  Been using it ever since, compiled the "C" code into ARX programs for R14.
Message 18 of 40
jochen2
Observer
Observer
Try out my PEDIT3D
Free download from
www.black-cad.de
Regards
Jochen
Message 19 of 40
autoid374ceb4990
@jochen2 wrote:
Try out my PEDIT3D
Free download from
www.black-cad.de
Regards
Jochen
Tried to load it.  Got a "Load failed' error.  Probably because I am using R14.
Message 20 of 40
autoid374ceb4990
For those who have written code to do this, how about some pseudo code to explain the steps you used to convert the lines to a 3D POLY?
